Fourtitude.com - Rear Door Panel Removal/Window Regulator Replacement DIY
    Results 1 to 25 of 35
    1. 05-29-2010 02:32 AM #1
      1. Open your door wide open
      2. Remove the tweeter cover. Remove the window switch top cover using a very thin wedge or something that won't damage the trim. Remove door trim. Remove 2 screws (t25)
      3. Use wedge/pry tool or something to pop out the interior door panel, starting from the bottom and working your way up along the sides, carefully. The unhook the top part of the panel from the tract, by pulling up forcefully.
      4. While holding the panel, use other hand to pop out the cable for the door and unhook it from the panel. Also you need to remove the connector near the speaker and the connector with a purple tab connected to the window motor.
      5. Remove 3 screws (t30?) that holds the motor to the regulator, which is on the other side the metal sheet. Admire the damaged regulator. Pinch the white tabs and push into the other side to unmount regulator.
      6. Pry/pop out the black plastic/rubber piece to gain access to the regulator when removing it later on. Remove 4 screws (t25).
      7. Pull out rubber pieces on each end of the door. This side and one near the hinges. Also, remove circle rubber cover which conceals another screw. Remove, all for screws (t40-45?)
      8. Remove that screw (t30?).
      9. Once all 9 screws are removed, pull out the top window frame towards you for about 2-3 inches and then pull up carefully, but forcefully.
      10. Remove the damaged regulator by sliding the window glass off and unscrewing the one screw (t25). Also, two other screws holding the glass to the regulator need to be removed. Then replace with new regulator.
      11. Replace the window frame by tilting it towards you and sliding it down into place. Will take a couple of tries, but you'll eventually get it in.
      12. Make sure that the screw holes are aligned and screw all 9 screws back together. Pop the window regulator tabs back into place.
      13. Reinstall everything.
      14. Done. 1- 1.5 hours max.
    3. Member TackeeA3's Avatar
      Feb 13th, 2004
      Chicago
      1,724
      2006 A3
      05-29-2010 02:58 AM #2
      Good job bud
      iiililillillliliil
      Bar Society
    4. 05-29-2010 03:00 AM #3
      thanks for the part. The hardest part of the job was posting these pics and editing them. hahah
    5. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      15,064
      2016 GTi AutoBahn; 2016 Tiguan R-Line; Gone but not forgotten: 2006 Audi A3 3.2T
      05-29-2010 12:28 PM #4
      Good work. Thanks for the photo DIY.
    6. Member renohuskerdu's Avatar
      May 1st, 2010
      France
      382
      RIP: 97 Vento VR6 Euro Climatronic; Range V8 tube/mud 4x4 beast: VR6 Golf III; Bora V5
      06-01-2010 09:51 AM #5
      Excellent post. Too bad you don't have a MkIII like mine
      French dude neben Deutschland. Das Leben beginnt mit crapmo' stank malt licky. Das Bardle Doo?
    7. Member FreeGolf's Avatar
      Sep 18th, 2003
      In, Out & Around...
      3,406
      Audi, BMW, Ferrari, LR, Porsche, & RR.
      06-01-2010 10:23 AM #6
      excellent write-up... thank you.
      side note, has anyone here swapped to oem window shade integrated door panels?
      curious on the price and the difficulty.
    8. 07-27-2010 03:51 PM #7
      Does anyone know where I can find a Rear Driver Side Window Regulator Repair kit? I'm having trouble finding one on the internet. Thanks.
    9. 05-08-2012 09:31 PM #8
      I am stocking (well, trying) all available Audi (and VW) window regulator repair clips for models sold in North America.
      I just came across a client with a failed front left window regulator.
      I am now contacting my European manufacturers to see if they make the A3 8P clips (front and rear), and I am in need of good photos showing the clip.
      Also looking for good, detailed DIY write ups for taking the door panels off, changing the regulator (and clips).
      Please PM or send email (photos!) to info@regulatorfix.com
    10. 05-08-2012 10:54 PM #9
      Quote Originally Posted by vtraudt View Post
      so you get a diy for free? i think the client needs to be compensated.
    11. 05-08-2012 11:21 PM #10
      Quote Originally Posted by TechnikSLR View Post
      The client is the one getting the clip.
      The forums get a source for clips at a reasonable price.
      But yes, I am 'compensating' those who contribute (and may become clients).
      They get free clips (only pay S&H) (either for models I already stock, or the clips I am trying to find manufacturers for).
      Currently stocking (examples) (clips in large quantity, as 'back up' for clients-in-need also small quantity of pulleys, typically just one set of cables) for those models:
      A3 (8L) front
      A4 (B5) front
      A4 (B6, B7) front, rear
      A6 (C5) front
      A6 (C6) rear (rare; took me a while to get that one)
      Passat front, rear (with the peg/pin)
      Golf front, rear
      Jetta front, rear
      Beetle front
      Jetta front (metal)
      Others: BMW, Saab, Volvo, Jaguar, Porsche, Land Rover, Mercedes, Ford Focus, some GM, Lincoln LS, Opel Astra,
    12. 08-26-2012 07:34 PM #11
      I had my rear driver side fixed at the dealer for $500. Now my rear passenger went bad I think I will try this DIY.
      Is this the right part or any where I can get the part cheaper?
      http://www.ecstuning.com/ES2206851/
    13. 08-26-2012 09:41 PM #12
      2011 A3 2.0T Monza silver metallic S Line
    14. 08-26-2012 09:52 PM #13
      Quote Originally Posted by ryuuoh View Post
      Awesome! Mine is 2006!
    15. 08-26-2012 11:46 PM #14
      Quote Originally Posted by xgarage View Post
      Well, "right" has a few interpretations:
      A) it could fit your (assuming you have the listed year/model/location
      B) you may only need the plastic guide clip. They are by far the most common cause for failure. I think I have them in stock. Ca $20 shipped in US.
      Sidenote: ECS is talkink about dusted cables as a cause. I have not seen one rusted czble causing an audi regulator to fail!
    16. 08-27-2012 01:35 AM #15
      U got PM!
    17. Member
      Jul 17th, 2001
      Philly burbs, PA
      4,404
      2015 VW GTi, 2012 VW Golf R, 2006 Audi A3
      04-30-2014 12:13 AM #16
      Just used this DIY... very helpful.
      Awesome write up/photos.
      I didn't see this in the FAQ section, but it should be there.
      Thanks!
    18. Member
      Jun 3rd, 2013
      Wilmington, DE
      1,810
      06 2.0T A3
      04-30-2014 08:56 AM #17
      Quote Originally Posted by vwlippy View Post
      Thanks!
      I used this one too. Like 8 times now
    19. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      15,064
      04-30-2014 09:30 AM #18
      Quote Originally Posted by BeeAlk View Post
      But that was more out of personal choice, not necessity.
      722 pages, 25255 posts, and 1,015,739 views later... R.I.P. LoL Bump thread 03/27/2008 ~ 02/16/2011.
      Link to my build: Audi A3 3.2 VR6 BT
      CleanAudi.com feature
    20. Member
      Jun 3rd, 2013
      Wilmington, DE
      1,810
      06 2.0T A3
      04-30-2014 11:17 AM #19
      Quote Originally Posted by krazyboi View Post
      Well, half true. Window regulator busted, then motor stripped, then door handle cable thing snapped, then I forgot to put the insulation back in lol.
      Good news is I can now take off the door card in about 3 minutes flat
    21. Member
      Jul 26th, 2010
      I be where I'm at.
      993
      2006 eh3 2.0T
      05-26-2014 05:49 PM #20
      Quick question on this DIY....
      I want to replace the metal triangle trim piece on the exterior of the rear door and from the pictures it looks like the bolt holding it in place is just inside the frame. Can I simply lift up the entire window frame after unbolting it from the door frame, and NOT actually have to remove the regulator? My windows are fine, but that trim piece needs some TLC so I want to swap it out with a new one I have.
      Thanks...
      *** Here's the piece I'm looking to replace
      #KeepFightingMichael
    22. Member
      Jun 3rd, 2013
      Wilmington, DE
      1,810
      06 2.0T A3
      05-27-2014 05:00 PM #21
      The regulator does not have to separate from the window frame to pull it out of the door. Not sure if that triangle piece requires removal of the regulator though.
    23. Member
      Jul 26th, 2010
      I be where I'm at.
      993
      2006 eh3 2.0T
      05-28-2014 12:06 PM #22
      Yea, that's what I'm not sure of either... I just don't wanna mess with it since it's working fine... But that triangle trim piece has got to go now that it's starting to look worse... I guess I'll take my chances...
    24. Member
      Jun 3rd, 2013
      Wilmington, DE
      1,810
      06 2.0T A3
      05-28-2014 04:44 PM #23
      You shouldn't screw anything up by removing the regulator if you end up having to do so..
    25. Member
      Feb 24th, 2012
      Costa Mesa, CA
      129
      2006 A3 2.0T
      06-22-2014 06:48 PM #24
      Great DIY, just replaced my left rear with a $50 replacement regulator from rockauto.com. Works GREAT.
    26. 07-05-2014 11:24 AM #25
      I think this is 2009-2011 year models.
