Fourtitude.com - PLEASE HELP QUICKLY: 05 1.8t passat multiple misfire and misfire cyl 3. WHERE IS THE ICM?
    Results 1 to 7 of 7
    1. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      14,366
      golfs on junior cupkits with a side of chalet sauce... lifted Jeep Wrangler
      02-03-2010 08:33 PM #1
      ok.. so it's giving codes for multiple misfire and misfire cylinder 3. i did some reading and saw that this could be caused by the ignition control module, or the ignition coils.
      the ignition coils i understand how to service, however i cannot find the ignition control module. i removed the airbox beauty cover and i don't see it there, which is where i thought it would be.. ?
      also, on ECS they list an ignition control module that supposedly works for all 1.8t's, however on GAP they say this is only for 98-99 with AEB engine code ECS also lists a plethora of different ignition coils.
      car is a 4motion if it makes any difference.
      can someone please steer me in the right direction?
      Quote Originally Posted by Paul Harley
      yo, is that a wolf?
      MODS IN THE SIG: MY MODS IS IN THE SIG!
    3. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      14,366
      02-03-2010 09:19 PM #2
      ok.. found out in the passat forum there is no ICM.
      anymore help or things to check?
      kind of sucks vag-com only comes up with misfires and not the root problem
      yo, is that a wolf?
    4. 02-03-2010 09:35 PM #3
      There is but its in the coilpack .
      The earlier cars had it on the airbox
    5. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      14,366
      02-03-2010 09:42 PM #4
      gotcha..
      well.. so can it really only be the coilpacks? it happened suddenly BTW.
      she was driving to work, and got within sight of where she works and all of a sudden the CEL flashed and the engine was shaking from misfire... she pulled over and called me, i told her to drive the maybe .25 to .5 mile to where she worked and when i scanned it a few hours later, cleared the codes and scanned it again, it came up with the codes listed above: cyl 3 misfire and multiple misfire
      yo, is that a wolf?
    6. Member nug548's Avatar
      Jan 28th, 2005
      green bay, wi
      1,299
      03' gti 1.8t, 88' jetta GL
      02-03-2010 10:31 PM #5
      whens the last time if any the coilpacks were replaced??? im guessing packs. i think thats the number one reason for misfires. if it ends up being the coilpacks, go to the dealer. their under recall right now!!!
      and yeah it can happen suddenly, one min your fine the other your engine is bucking and doesnt want to go
      Modified by nug548 at 8:32 PM 2-3-2010
      03' GTI 1.8T-----
      X+, APR TIP, MBC, ECS race valve, 3" catless DP to 2.5" with magnaflow muffler, 14lb. FW and vr6 clutch, gutted air box w/ bottom cut, K&N filter, 4 bar FPR, BRK7E's, forge 007p DV, N249 deleted, forge boost hose kit
      88' jetta GL--- sold
    7. 02-03-2010 10:31 PM #6
      Yep
      Buy a set of 4 and keep the others as spare .
      I know there is a recall in US for there , maybe ring a dealer get them to check your vin to see if your car is affected ?
    8. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      14,366
      02-04-2010 12:13 AM #7
      thanks guys.. it is the coilpacks.
      i switched the coil on cyl 3 to cyl 1 and got the same code on that cyl.
      i contacted the dealership.. we'll see. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      yo, is that a wolf?
