Fourtitude.com - 9a vs aba
    Results 1 to 6 of 6
    Thread: 9a vs aba
    1. Member lostsurferinbc's Avatar
      Nov 8th, 2007
      the best place on earth
      1,698
      1989 jetta trophy edition, 2007 rabbit
      12-18-2009 12:58 PM #1
      sorry for the noob questions guys, Ive decided to have a 16vt built. my question is which is a better platform, the aba or 9a and why? cost wise, parts availability, reliability ect.....
      my goal is around 250 whp
      this is the car that will get the new heart
      Nov 12th, 2007
      Hubbard Oregon
      112
      1988 vw GTI
      12-19-2009 02:21 PM #2
      i at one time was lookin into doin a 16vt also and i found that with the aba block it is slightly taller and gives you a little longer stroke which equals more torque the 9a is a little shorter but the difference in stroke i dont think is noticable, for price and avaliability the aba block hands down there are so many of them for dirt cheap and if i remember right the early aba's hand factory forged crankes which is always good for boost, there is nothing wrong with the 9a if thats what you got then build it but in my area aba's are in every wrecking yard and are a dime a dozin
    4. Member sp_golf's Avatar
      Nov 28th, 2007
      Toronto
      3,904
      88 Golf 16vT
      12-19-2009 04:36 PM #3
      Quote, originally posted by JohnK88GTI »
      that's mostly mis-information
      Both 9A and ABA will work, costs are around the same, the ABAs are a lot more common. The good thing about the ABA is that it has a built in crank position sensor which is good if you're gonna go stand alone, also the rod/stroke ratio is better because of the taller block/longer rods, so there is less stress on the pistons/rods at higher rpm, and the compression ratio is also lower with the stock ABA pistons.
      If you have a 9A block, use it, if you're starting from scratch and you want to use the ABA block, you will need the intermediate shaft, oil pump, distributor block off and and timing belt crank gear from the 9A.
      I'd personally use the ABA block if I were starting from scratch, and for 250whp, I would just do a stock rebuild with ARP head bolts and rod bolts.
      SP Solutions
    5. Member GTijoejoe's Avatar
      Oct 5th, 2001
      7,684
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      12-19-2009 05:51 PM #4
      I would use a stock ABA bottom end...250whp = no problem
      2.0T+034efi+meth = 300+whp = RIP
      Quote Originally Posted by Ryukein View Post
      Everyone always praises function over form until the form is something that they don't like
      FS: 2015 Honda CRV Touring
    6. 12-20-2009 10:07 PM #5
      343whp 353wtq out of a 9a with stock head. I think I may skip the ABA and jump right to an 06x motor this winter. We'll see.
      But for 250.. I wouldn't do anything more then stacked gaskets and ARP head studs on a complete 9a motor.
    7. Member boost_addict's Avatar
      Dec 4th, 2009
      souderton pa
      1,963
      VEMS Audi S2 , & VEMS sponsored GTI.
      12-21-2009 10:48 PM #6
      Quote, originally posted by Jeebus »
      agreed for only a goal of 250, i would stack gaskets on the 9a. if you do not have a 9a already i would get an aba obd1 bottom end. (obd1 has oil squirters too)
      PTE 67m VEMS powered VR6 Audi S2
