Fourtitude.com - Transmission Jerky (Fault Code: 00300, 00268, 01045)
    Results 1 to 2 of 2
      Oct 29th, 2002
      Queens/LI, NY
      367
      2011 Jetta TDI DSG NAV, 2010 JSW TDI, Audi Q7 4.2 Premium (Sold), 2003 Jetta GLS 1.8T
      12-16-2009 03:39 PM #1
      Transmission seems to be jerky so I've scanned with VCDS and here's the code that I got.
      2003 Jetta 1.8T - Milage: 61553 miles
      Address 01: Engine Labels: 06A-906-032-AWP.lbl
      Part No: 06A 906 032 LQ
      Component: 1.8L R4/5VT G 0005
      Coding: 07550
      Shop #: WSC 00066
      3VWSE69M23M053736 VWZ7Z0B5861243
      1 Fault Found:
      18032 - MIL Request Signal Active (Check TCM for errors too!)
      P1624 - 35-00 - -
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 09A-927-750.lbl
      Part No: 09A 927 750 AJ
      Component: AG5 Getriebe 09A 0215
      3 Faults Found:
      00300 - Transmission Fluid Temp. Sensor (G93)
      27-10 - Implausible Signal - Intermittent
      00268 - Solenoid Valve 6 (N93)
      30-10 - Open or Short to Plus - Intermittent
      01045 - Tiptronic Switch (F189)
      27-00 - Implausible Signal
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: RADIO 3CP 0003
      Coding: 00401
      Shop #: WSC 22503
      5 Faults Found:
      00878 - Connection to Speaker Front Left
      36-00 - Open Circuit
      00879 - Connection to Speaker Front Right
      00880 - Connection to Speaker Rear Left
      00881 - Connection to Speaker Rear Right
      01042 - Control Module; Not Coded
      35-00 - -
      FYI, the transmission (5-speed tip) has never changed oil (is it lifetime fluid? if not, what's the interval?) Please advise what I should do. Thank you.
    3. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      4,004
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      12-16-2009 10:14 PM #2
      Quote, originally posted by SGI »
      Vw calles it lifetime but that is baloney. I would advise changeing every 40-50,000
      You need to diagnose why you have codes.
      Solenoid code is usually solenoid, but can be wiring or computer. Ohms checks can pinpoint the problem if its not intermittant. Amp checks are helpful also.
      Tip switch code is usually the tip switch. You can watch the switch function on vag-com.
      Temp sensor code is usually temp sensor but can be wiring or computer (rarely computer) Temp sensor is deep inside trans requiring trans removal and disassembly to replace. I came up with a "experimental fix" idea. See following thread. You can moniter the temp on vagcom to see if it behaves like it should.
      http://forums.vwvortex.com/zerothread?id=4487328
      Modified by CoolAirVw at 7:29 PM 12-16-2009
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
