Quote, originally posted by monkeytronic » what's the difference between G 052 162 A1 and G 052 162 A2 ATF? one
#1
The '02 A6 4.2 is due for its ATF change and I'm researching what other brands of ATF I could use that meet Audi specs for the ZF 5HP24 5-speed automatic that the A6 sports.Apparently the 5HP24 prefers G 052 162 A2 ATF but a number of ATF brands seem to be compatible with G 052 162 A1 ATF. That said, what's the difference between G 052 162 A1 and G 052 162 A2 ATF?
#2
Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
www.KansasCityTdi.com
#3
Quote, originally posted by CoolAirVw » one
Well, besides the part number, that is.
Is the A2 fluid a full synthetic (or more synthetic semi-synthetic blend) compared to the A1 ATF?
Also given that BMW has used a RWD-only version of the 5HP24 in its 5-series and 7-series cars that called for Esso LT 71141 ATF is this another option that could be used in the A6 as well?
#4
Answering my own question:The difference between both part numbers is the volume of the bottle they come in. They are actually the same ATF.
G 052 162 A1 = 0.5 L bottle (approx. 1 pint)
G 052 162 A2 = 1.0 L bottle (approx. 1 quart)There's also...
G 052 162 A6 = 20L bottle (approx. 5-1/4 gallons)
