Fourtitude.com - Basic Setting: Throttle Body Adaptation
    Results 1 to 3 of 3
    1. Junior Member static9's Avatar
      Jun 5th, 2008
      Austin, TX
      37
      2001 1.8t Jetta AWW Green (totaled), 2002 darkblue TDI AHL, 2008 R32 UG un-numbered - sold
      07-06-2009 01:45 PM #1
      Group 060: Speed Regulation (Basic Setting: Throttle Body Adaptation)
      14.1 % Throttle Drive Angle Sensor 1
      84.8 % Throttle Drive Angle Sensor 2
      8 Learn Step Counter
      ADP. O.K. Result Throttle Valve Adp.
      the codes after...
      17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
      P1171 - 35-00 - -
      17987 - Throttle Actuator (J338): Adaptation Not Started
      P1579 - 35-10 - - - Intermittent
      there is a Wiki on error that led me to do this, but it never says "ADP RUN" always ADP. O.K when I try to set Adaption. Can someone tell me why this is? Car goes into LIMP mode alot and it seems to be random or on really hot days it happens almost always and clearing the codes doesnt always work.
      Modified by static9 at 3:05 PM 7-6-2009
      Apr 1st, 2009
      Piedmont Triad, NC
      237
      2002 GTI
      07-08-2009 12:47 AM #2
      Check mainly in the Automatic transmission forum, you may find answer there.
      What you do does not matter, how you do it does.
    4. Member Elcroato's Avatar
      May 21st, 2002
      Sicily
      439
      2010 GTI, 2000 Skoda Octavia 1.8T
      07-08-2009 05:30 AM #3
      While running the adaptation it says adp run in the same field as adp ok afterwards. Did you try to clear the codes and run the adaptation again?
      2000 Skoda Octavia 1.8T, mods: Revo Stage II, 4 bar FPR, INR tranny and engine mounts, 3" Draft 42 catless turbo back exhuast, vRS front bumper
      2010 GTI, mods: Wavetrac LSD, APR Stage II, APR downpipe
