+ Reply to Thread
Results 1 to 9 of 9
Thread: 06 Passat rear parking brake problems
  1. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    7,125
    2010 VW JSW, 2001 Porsche 996, and 2004 Audi A8L
    06-05-2009 08:45 PM #1
    Long story short I had trouble installing new rear brake pads. Now I have a flashing parking brake light that beeps at me. Here is the scan:
    Friday,05,June,2009,19:32:19:35305
    VCDS Version: Release 805.4
    Data version: 20090602
    Address 53: Parking Brake
    Control Module Part Number: 3C0 907 801 B
    Component and/or Version: EPB VC8HC001 013 0001
    Software Coding: 0000013
    Work Shop Code: WSC 131071
    1 Fault Found:
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 88008 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 19:16:42
    Freeze Frame:
    Voltage: 13.56 V
    Count: 87
    SoWo Partners
    www.sowopartners.com
    Check out our webpage for SoWo, Kleen Freaks, and Liqui Moly Product Deals!
  2. 06-06-2009 01:09 AM #2
    I know this sounds dumb but check you fuse. It's #5 on the drivers side.
  3. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    7,125
    06-06-2009 09:34 AM #3
    Quote, originally posted by colbyjoe »
    I will check that tonight. That would be AWESOME if it was something that simple.
    SoWo Partners
  4. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    1,137
    All original 77 Rabbit; 12 Prius C; 13 Jetta
    06-06-2009 03:52 PM #4
    This may (or may not) help. It's from a TSB found in the B6 forum.
    http://geocities.com/nfe100/Te...e.pdf
    Good luck...
  5. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    7,125
    06-07-2009 07:39 PM #5
    Alright guys I didn't see any blown fuses and the TSB didn't work. Here are the new codes. I am going nuts trying to figure this out and don't want to take it the dealer to get raped.
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 88008 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 19:16:42
    Freeze Frame:
    Voltage: 13.56 V
    Count: 87
    Sunday,07,June,2009,18:34:07:35305
    2 Faults Found:
    01315 - Transmission Control Module
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 88016 km
    Time Indication: 0
    Date: 2009.06.05
    Time: 02:00:53
    Freeze Frame:
    Voltage: 10.77 V
    Count: 224
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 222
    Mileage: 88008 km
    Time Indication: 0
    Date: 2009.06.03
    Time: 19:16:42
    Freeze Frame:
    Voltage: 13.56 V
    Count: 87
    SoWo Partners
  6. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    1,137
    06-07-2009 09:10 PM #6
    OK, found you a better one - the DTC and your controller part number both are shown in this TSB. I think this is your answer - but probably not what you wanted to hear as it involves the dealer. Maybe you're still under warranty...
    http://www.geocities.com/nfe100/Technical_Bulletins/2007.05.15_update_program_Elc_park_brake.pdf
  7. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    7,125
    06-07-2009 10:21 PM #7
    Never had a TSB done before. If I am out of warranty will I be charged for this service?
    SoWo Partners
  8. 06-07-2009 11:19 PM #8
    The procedure is a update for the Parking brake module.
    TSB stands for Technical Service Bulletin and there are a LOT of them.
    Since the vehicle is out of warranty, then yes you should be charged for it.
    If you are within 12,000 miles and 1 year from the expiration of the W2 / bumper to bumper warranty, then go to the dealer you bought it from and ask for Goodwill.
    Most dealers will work with you and honor the Goodwill. If you go to a dealer you did not purchase the vehicle from and never get any service from, they may not.
  9. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    7,125
    06-08-2009 08:46 AM #9
    Quote, originally posted by dana vw tech »
    Working with a friend of mine at the dealership to try and get "goodwill". Thank you for the help.
    SoWo Partners
+ Reply to Thread
