Fourtitude.com - Jetta dies at redlight....code P0322
    Results 1 to 25 of 29
    1. 04-29-2009 06:16 PM #1
      So I was driving around and my Jetta died while at a stop light. I turned the key and after 2-3 sec the car stated back up but the EPC light was on. Drove into a parking lot, turned the car off and back on. Started up with out an issue but now the check engine light was on. Lucky for me I was only a few miles from a part shop and was able to look up the code. While stopped the car died again and started up after 3-4 attempts. Drove nice and easy and was able to make it to the store. The code was
      P0322 “ignition/Dist Engine Speed input Circuit no signal”
      Of course I was WTF does that mean so I had the guy look it up. Their little computer stated “poor electrical connection or faulty CKP sensor”
      After checking the code I go to start the car and it won’t start. Pissed off cranked the engine for about 15-20 sec and it started up however it would not go above 3000 RPM.
      So I take it that my crankshaft sensor is bad and needs to be replaced. Does that sound right?
      Where is it? What does it look like? Is it easy to do? And is this going to cost me my left nut? Anything cause the sensor to fail or are they just junk?
      Oh yeah I have a 2005 Jetta 2.5L with just over 60,000 miles on it.
    3. 04-29-2009 06:56 PM #2
      ok car been sitting for a hour......starts up fine and able to get the RPM above 3000. EPC light is off but the check engine light is still on.
      dealer wants $200-250 in labor plus $50 for the part.
      Mar 21st, 2005
      Weaverville NC & Sebring FL
      128
      13 Passat TDI & 04 Jetta 1.8t
      04-29-2009 10:53 PM #3
      If it is the crank sensor on the bottom of the crank mounted close to the engine/tranny, it takes about 30 secs to change it. Unplug the harness, two allen bolts, and reconnect. They do fail, and they don't get better once they fail.
    5. 04-29-2009 11:17 PM #4
      can you give a little more detail on the location. it is hard to see anything.
      anyone have a pic?
    6. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      11,510
      2016 Mazda CX-5 2006 Volkswagen Jetta 2013 Ford Focus Electric
      04-30-2009 12:33 AM #5
      I haven't heard of CKP sensors being faulty on Jettas before but I'm curious to see how things turnout.
    7. 04-30-2009 07:22 AM #6
      i have searched the forum and found a bunch of older jettas (old body style and different engine) that have failed. guess the 2.5 has the same issues.
    8. Member Trua's Avatar
      Apr 10th, 2007
      Coral Gables, FL
      218
      2007 VW Rabbit
      04-30-2009 12:24 PM #7
      I have the same problem on my car. It happens when I drive the engine cuts off and then back on with the epc on. I turn off the car and back on the the light goes away. I'm waiting for the car to do it again for I could take it to the dealer.
    9. Junior Member cbloyer81's Avatar
      Jan 13th, 2011
      Denver
      37
      2004 VW GTI
      06-30-2011 06:31 PM #8
      I did a quick write up of this procedure.
      I was getting the following codes at about 90,000 miles:
      2 Faults Found:
      000802 - Engine Speed Sensor (G28): No Signal
      P0322 - 004 - No Signal/Communication - Intermittent - MIL ON
      I fixed the code by going to the dealer and picking up what they called the crankshaft position sensor. I know when I was investigating this I was trying to figure out what the difference was between the engine speed sensor, crankshaft position sensor, and the camshaft position sensor. The engine speed sensor and crankshaft sensor are the same thing. The camshaft position sensor is different.
      The part number for the crankshaft position sensor is 07K-906-433-B and it lists for $63.03.
      Here you can see the location of the sensor.
      Here you can see the two fasteners holding it in.
      There are two tie down points for the cable. Be careful with the metal one, it will stay on the old sensor and you'll think you lost it.
      This is where the harnes connects. Remove it from it's bracket and disconnect.
      Two photos of the sensor.
      Installation is the reverse of removal.
    10. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      11,510
      07-03-2011 01:00 AM #9
      Quote Originally Posted by cbloyer81 View Post
      Awesome write-up!
      I think you solved the mystery of why my car had the EPC and CEL illuminate while driving through a humongous downpour in Florida. That sensor is exposed such that I could see it getting troubled by water intrusion.
    11. Member eatrach's Avatar
      May 13th, 2004
      Upland
      964
      '09 VW Jetta 2.5L auto, 2016 Golf Sportswagon SE, 2016 BMW X5 3.5 S drive
      08-26-2011 10:15 AM #10
      just had CEL and EPC lights came on. I have to yet check out the codes; too dark outside.
      But car is running rough. Dang it, and I have two patients to attend to today.
    12. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      15,332
      2016 GOLF 1.4 TSI
      08-28-2011 06:56 PM #11
      must drain oil before?
    13. n00b
      May 29th, 2013
      Minneapolis, MN
      7
      05 MK5 Jetta 2.5L Auto PK1
      05-29-2013 01:11 PM #12
      were you able to fix your problem by replacing the crankshaft sensor ?
      Im having the same exact problem at 108k miles, to replace the EPC is 1000 plus calibration
      - I dont think you need to perform an oil change to replace the sensor ....do you ?
      Thanks
    14. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      5,759
      MK7 GTI, 90 Corrado 16vt
      05-29-2013 07:39 PM #13
      Quote Originally Posted by curbaez View Post
      Thanks
      If you are having the same issue it is very likely the crank sensor. Its always tough to say for sure because there are a lot of different reasons why things can happen. You should not need to drain the oil to install this part. Should just be the 2 5mm allen bolts that hold it in.
      http://www.deutscheautoparts.com/Vie...433-B/0/150127
      ShopDAP.com ---------Deutsche (DOY-chuh) Auto Parts----------All VW part numbers are searchable on our site.
      Follow us on Instagram-------- Twitter --------Facebook--------- YouTube
    15. n00b
      May 29th, 2013
      Minneapolis, MN
      7
      06-03-2013 02:42 PM #14
      thanks to autozone for the crankshaft sensor $53 bucks
      problem went away ....
      Thanks
    16. 09-24-2013 11:51 AM #15
      My 2005 Jetta 2.5 had this same problem since last week.. I just replaced the crankshaft position sensor and its gone now..
      except the part I got from autozone (duralast i think).. one of the screws broke when I tightened it too much.. but the other screw is holding it pretty well and Im not sure if I should try and remove the broken screw using a screw extractor and put in the one from the old sensor..
      Im just planning to wait it out.. if I see any oil leaks then I might try that route..
      But thanks guys.. I thought this was going to burn a big hole in my wallet.. hopefully I wont have to touch it again..
    17. 03-20-2014 01:36 PM #16
      on ebay these range fro $6 to $90. wonder what the difference is between the $6 and the $90. other than $84
    18. 02-23-2015 11:19 PM #17
      Same symptoms - Started car in parking lot, began to accelerate and car bogged down and nearly stalled but I pushed in clutch and save it. Car drove okay, but no more than 3K RPM. EPC light on. Drove for 1 mile and decided to turn car off and then back on. It took about 15 seconds of cranking for car to fire and now check engine light and EPC. Limped home, reset ECU (pulled positive battery cable and reconnected - car wouldn't start at all) and called to get it towed to dealer. While waiting for tow truck, found this forum and cancelled tow and drove wife's car to VW to pick up the crankshaft position sensor. Came back and spent an hour replacing sensor (NEED longer allen wrench) and once complete, engine fired up immediately. Yeah!! THANK YOU VERY MUCH!!
    19. Junior Member cbloyer81's Avatar
      Jan 13th, 2011
      Denver
      37
      2004 VW GTI
      02-23-2015 11:38 PM #18
      I'm glad to see this is still helping people.
      - No need to change the oil, but it looks like you guys figured that out.
    20. Member Blkzilla's Avatar
      Jul 24th, 2008
      Dallas, Texas
      223
      2008 VW Jetta S
      03-02-2015 05:05 PM #19
      Are you guys running stock intakes? I have a P-Flo. P0322 is one of the codes I'm getting. The others are P0102 & P0113. I believe the P01* codes are related to the intake air/fuel ratios being out of wack. My question is can the P01 codes cause the Crank Shaft Position sensor to fail?
      My car is currently at the shop. Rep wants to install the factory airbox before proceeding w/ diag. I'm curious as to what the final diag will be, now that I've found this thread.
    21. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,931
      1k-m-cbta-02q-PTE5858
      08-05-2015 03:45 PM #20
      Bump.
      I'm having this issue, and i just ordered the sensor. Will install later tonight and then will confirm the fix.
      I have all the symptoms including the random no start, the bog downs, the random limp modes, the random misfires, etc.
    22. 08-05-2015 04:41 PM #21
      ^^ in for results.
    23. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,931
      08-06-2015 10:22 AM #22
      Quote Originally Posted by le0n View Post
      ^^ in for results.
      i was going to change it yesterday but i saw that i had grease all over. CV boot thing needs replacing. I Will maybe change the sensor today.
    24. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,931
      08-10-2015 10:28 AM #23
      Changed the sensor last night, the car started without hickups, no CEL, no nothing.
      All is good in the world.
      I diagnosed the issue easily: i was going to run some logs, and saw that vag com was randomly telling me about misfires, and it was cutting off on the RPM signal. Then i got the code 0322, and right away it was clear that the RPM sensor was going bad.
      Replacing takes... 30 mins total? remove the undertray and then just unplug, and unbolt. Easy.
    25. 08-10-2015 11:52 AM #24
      ^^ nice.
      I wonder if I should just buy this sensor to have on hand.
    26. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,931
      08-10-2015 12:17 PM #25
      Its $100 at the dealer, or 50 with the above post.
      Buy it whenever the car starts miss behaving. I've been having random and irregular issues for the last 2 months, when the sensor was working intermittently. It finally gave up last week.
