Fourtitude.com - my aba/16v turbo build..
    Page 1 of 7 12345 ... LastLast
    Results 1 to 25 of 163
    1. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      2010 GTi,1998 GTi (stock),1998 GTi(aba/16vT),1998 A4,1997 A6,1995 A6..etc..
      04-08-2009 02:02 PM #1
      My aba/16v turbo build...finally..
      The car is a 1998 t-red 2.0GTi, believe it or not its rust free,garage kept her whole life...Ive been assembling parts for a long time now so hopefully it will all go smoothly and quickly. My goal is to have her on the road again by waterfest but im not getting my hopes up b/c I still have some large hurdles to tackle...I should add that this is a starting point, after h20 im planning on taking it all back out and shaving the bay,etc..Enough of the b.s ill get on to the good stuff...
      Engine:
      obd1 block (forged internals and oil squirters)
      wossner custom abf pistons with valve cutouts
      lightened and balanced crank
      shot peened rods
      kent cams heavy duty longblock 16v t-belt
      new t-belt tensioner
      new waterpump
      low temp thermostat
      new main,rod, and intermediate shaft bearings
      once assembled it will be balanced
      vf engineering mounts
      (im probably forgetting some things but its a start)
      im working on making my own "dizzy gizzy"...ill update on that later
      Induction:
      Bought a Holset hy35 and a rebuild kit flows 60lbs/min(600+hp)
      log style t3 flanged ext. gated manifold
      cx racing 38mm wastegate w/external dump
      greddy type rs bov
      cx racing intercooler and piping (to start)
      Water/Meth injection to top it off..
      Software:
      MsNsE w/Sequential C.O.P
      Transmission:
      02a Corrado
      Limited slip Diff...
      vr6 stage 2 clutch kit
      vr6 lightened flywheel
      Suspension:
      H&R cup kit(NEED)
      Front and rear upper and lower sway bars(NEED)
      Alot of other stuff eventually...
      ...will edit post to add more..enjoy
      *Anything that has (NEED) next to it I would appreciate help sourcing*
      TIA
      Modified by JustTheTip at 11:27 AM 11-23-2009
      I like cars.
    3. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      2,216
      08 A8L 4.2/98 ABA16vT GTI/UH-60A/L
      04-10-2009 09:11 AM #2
      all you'll need is a 38mm unless you go bigger on the turbo... everything else looks pretty good... whats the comp ratio yield on the wossner abfs?
    4. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-10-2009 09:24 AM #3
      8.0-1...high boost...
      I like cars.
    5. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      2,216
      04-10-2009 09:32 AM #4
      damn... i was thinking about getting pistons done for mine, but probably closer to the 9.5:1 range
      you getting any headwork done?
    6. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-10-2009 09:48 AM #5
      For now its gonna be stock brand new head,i wanna break in the block/tune the megasquirt i just ordered yesterday (and give the wallet a break).while she is still on the road im going to build up one of the other heads I have laying around w/titanium springs/retainers,oversized valves..etc..
      Modified by JustTheTip at 6:35 PM 4-28-2009
      I like cars.
    7. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-10-2009 09:51 AM #6
      edit: im going to be running 10psi this year,then going for high boost and over 400 whp next year..just hope the corrado 02a can handle it..
      I like cars.
    8. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-11-2009 08:59 AM #7
      so the front end is off ready for the engine/trans to slide right out when i borrow my buddy's hoist..got some ****ty pictures from my iphone...ill try to get them uploaded..
      I like cars.
    9. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-16-2009 07:20 PM #8
      up top to help source parts to get this going..!
      Modified by JustTheTip at 2:16 PM 4-21-2009
      I like cars.
    10. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-21-2009 02:19 PM #9
      im planning to get this as much together as possible may 1-3rd..any help finding the manifold and other stuff is appreciated!!
      I like cars.
    11. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-24-2009 10:54 PM #10
      here are some teaser shots from my iphone of the intake manifold and the short block that finally came back from the machine shop..but was worth the wait. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      rmr did a great job on the manifold thanks to Issam
      enjoy...
      Modified by JustTheTip at 10:57 PM 4-24-2009
      Modified by JustTheTip at 10:58 PM 4-24-2009
      Modified by JustTheTip at 11:00 PM 4-24-2009
      I like cars.
    12. Member dub101's Avatar
      Jul 19th, 2002
      Maple Shade
      610
      99 jeep cherokee
      04-25-2009 10:15 PM #11
      WOW
      that manifold looks awsome. I hate that I missed that buy. Are the wossner pistons forged turbo units? Looks sick! cant wait to start my abf build.
      Stan
      Stan
      mk2 20v turbo
      11.65@123.5 and all motor cars are still faster...
      www.full-circle-industry.com your philly area VW Audi Porsche dealer alternative and home of PES Tuning! Affiliated w' USRT
    13. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      2,216
      04-25-2009 11:15 PM #12
      it's been over a year, no need to beat a dead horse. i was bummed out that i couldn't get on with the group but that's it, other opportunities will arise!
      Modified by 20B_envy at 9:17 AM 4-26-2009
    14. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,470
      91 Audi 80 2.0T
      04-26-2009 03:02 AM #13
      Quote, originally posted by 20B_envy »
      i'm pissed too man... i was originally on the list then got hit with a dui and couldn't pay right away even though i had guaranteed money coming in another 2 weeks and issam bumped me off the list
      You asked to be taken off the list?
    15. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-28-2009 05:17 PM #14
      well thanks to issam I should have my turbo manifold very soon
      The msnsv3.0 board is about half way done..
      Once i get my arp headstuds(tomorrow) ill bolt the head on and time it..
      before I put the new engine and 02a in Im going to convert the shifter/clutch setup, clean the bay and re-wire the entire bay from relay board to headlights I cant wait for that part...
      I like cars.
    16. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      04-28-2009 06:28 PM #15
      Quote, originally posted by dub101 »
      WOW
      Stan
      yes..they are the wossner low compression forged pistons...sorry must of missed your post for a minute..
      I like cars.
    17. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-07-2009 08:28 PM #16
      Never loaded pics of the progress so far so:
      I purchased a hy35 off a guy in ohio and he never shipped it and was ignoring me so im waiting on paypal to refund my money..F'ing dirtbag
      In the mean time I bought another hy35 and when I took it apart to rebuild it this is what I found..
      I like cars.
    18. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-07-2009 08:29 PM #17
      obviously that used to be the turbine wheel..another F'ing dirtbag..
      I like cars.
    19. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      2,216
      05-07-2009 08:44 PM #18
      ouch... that's one haggard turbine wheel
    20. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-08-2009 07:47 AM #19
      yessir it is, Its gonna cost me 400$ to replace my turbine wheel/shaft then send out both wheels,shaft, the two thrust washers and piston rings to be balanced. Itll take about a week turn around (hopefully) but the good news is that I can remove everything from the the center section, acid dip it,then rebuild it/polish compressor housing and acid dip the turbine housing while they have the shaft and wheels. I am going to try out this ceramic coating I found, they say its good to over 1500 degrees but we'll see. The compressor wheel still looks brand new:
      So when this process is complete this thing should look/perform like brand new..
      Modified by JustTheTip at 8:03 AM 5-8-2009
      I like cars.
    21. Member
      Nov 23rd, 2005
      Louisville KY
      333
      2004 R32
      05-09-2009 02:47 PM #20
      For another 195.00 you could have a new T3/T4 shipped to you. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I have one of these, 15 psi for a while, no problems...
      http://forums.vwvortex.com/zerothread?id=4056485
      Modified by tg60dd at 11:53 AM 5-9-2009
    22. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-10-2009 02:09 PM #21
      thanks but im sticking w/my holset. I love there technology..
      I like cars.
    23. Member 20B_envy's Avatar
      Mar 16th, 2006
      Ewing, NJ
      2,216
      05-10-2009 02:59 PM #22
      holset FTW
    24. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-14-2009 09:51 AM #23
      I like cars.
    25. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-21-2009 09:54 PM #24
      the head is bolted on and torqued,waiting on machine shop to finish w/my intermediate shaft conversion to time it, until they get done w/it i have plenty of other things to finish; wiring, msns/e board, polishing compressor housing..etc..
      here's some more eye candy
      Here's the compressor housing:
      ..more to come soon...
      Modified by JustTheTip at 9:50 AM 5-23-2009
      I like cars.
    26. Member JustTheTip's Avatar
      Jan 22nd, 2008
      West Chester,PA
      710
      05-21-2009 09:58 PM #25
      Forgot two...
      Modified by JustTheTip at 9:54 AM 5-23-2009
      I like cars.
