Fourtitude.com - New Product Development 2.5L L/W Single Mass Flywheel and Clutch kits , Shipped Ground Lower 48
    Page 6 of 6 FirstFirst ... 23456
    Results 126 to 143 of 143
    1. Member shysty's Avatar
      Oct 19th, 2010
      Ontario, California
      1,080
      09-10-2014 01:13 PM #126
      bump
      Sep 14th, 2008
      Tacoma, WA
      654
      '09 Jetta 2.5
      09-13-2014 01:33 PM #127
      What's the difference between the Kevlar stg 2x and fiber carbon stg 2x? Both are same price and same torque rating
    4. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      1,980
      92 Corrado SLC , 92 Audi S4
      09-16-2014 03:02 PM #128
      Between those two listed above, the difference would be longevity.
      Kevlar has a finite life where the fiber carbon would last a bit longer.
      Kevlar is suited to track or strip use, not ideal for daily driving, as stop and go could result in overheating of the disc.
      Kevlar won't recover from overheating, and will slip.
      Carbon doesn't suffer the same fate as Kevlar, but can take more abuse.
      Both will wear the PP and FW faster than organic.
      Choosing the correct friction material should take into account the type of driving that you plan on doing.
      Also take into account your current or future torque level.
      Organic stg 2 would be good for 375 ft/lbs .
      Organic stg 1 would be good for 275 ft/lbs.
      :: www.FourSeasonTuning.com
      :: United Motorsport-Wossner-Supertech-Clutchnet-DXD/SBC-Koni-Stoptech-Racingline-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
      :: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
    5. Member
      Sep 14th, 2008
      Tacoma, WA
      654
      '09 Jetta 2.5
      09-19-2014 11:18 PM #129
      Quote Originally Posted by FourSeasonTuning.com View Post
      Thank you, you guys are so helpful
      May 5th, 2013
      GTO, GTO, MX
      4,863
      A handful o' hatchbacks
      12-04-2014 02:08 PM #130
      I really want to recommend dealing with these guys. Better over the phone support than I'm used to and the after the sale customer service can't be beat!
      Quote Originally Posted by SSLByron View Post
      A Tuscan is a motor wrapped in plastic and held together by prayer.
      Quote Originally Posted by jnm2.0t View Post
      I'm here for the gangbang.
    7. Member BADpolizei's Avatar
      Jul 17th, 2006
      Palos Verdes Estates, CA
      147
      08/Volkswagen/Rabbit
      02-12-2015 11:00 PM #131
      Placed a order yesterday after my clutch went out on the way home from school. Shop got it today and I should have the car back by this weekend.
      .:08' Volkswagen Rabbit - Candy White - 5-Speed - 2.5L- 127k:.
      Stubby Antenna - Carbonio Intake - APR Stage I ECU + CAD Del. - USP Testpipe - TT Single Muffler - NLS Short Throw Shifter - 18x8 R32's - FST Single Flywheel Clutch Kit
      .:01' Volkswagen Jetta Wolfsburg Edition - Galactic Blue - 5-Speed - 1.8T - 60k - Totaled:.
      Jan 8th, 2012
      the netherlands/europe
      230
      2.5 T corrado syncro 1997
      07-15-2015 07:26 AM #132
      I have a 5 cylinder BGQ engine with a turbo in a corrado 4x4.
      On this engine a use a G60 flywheel.
      I am searching for a clutch that can handle up to 425 ft/lbs but don't want to change the flywheel.
      Also I don't want to push the crankshaft out of the motorblock, had a sachs race enginering clutch and did not like it at all, had the feeling I was training my left leg in a gym.
      The pedal engagement should be about normal, my wife is supposed to be able to drive in the car as well.
      Because of the 4x4 drive train the wheel torque will not be reduced, no wheel spin.
      Is there any cluch for this car with the specs I described?
    9. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      1,980
      07-21-2015 05:49 PM #133
      Quote Originally Posted by stef 4x4 View Post
      Not at your power level without the firm pedal as you described above.
      A stage 2 clutchnet might work for you even though you are beyond the max the mfg is rating these at.
      Here are the specs;
      Clutchnet Heat Treats the OEM Sachs Diaphram for a increase in clamp load.
      Clutchnet also uses A triple strap instead of the two supplied in stock form. Upgrades the size of the rivits.
      Sachs Castings
      Sachs friction surface
      http://www.fourseasontuning.com/46/1...see-below.html
      Jan 8th, 2012
      230
      07-23-2015 01:16 PM #134
      Here are the specs;
      Sachs Castings
      Thank you for your answer.
      One more question: how much costs shipping to the Netherlands?
    11. Member
      Jan 8th, 2012
      230
      08-06-2015 07:05 AM #135
      Here are the specs;
      Sachs Castings
      Took a look at your home page and saw the clutchnet stage 2 and stage 3 use the same pressureplate.
      If so, the power to release the clutch should be also same.
      So the difference in torque is caused only by the difference in clutchplates?
    12. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      1,980
      02-11-2016 03:24 PM #136
      Sorry this was missed. The friction material changes the torque level.
    13. Member ChunkyPeanuts's Avatar
      Feb 2nd, 2010
      Worcester MA
      3,025
      FSI GTI / B7 2.5 / Stock Gen2 Touareg /Mk2 Gli CIS
      02-15-2016 09:13 PM #138
      do these fit the b7 Passat clutches as i see them always being advertised for jetta / golf etc
    14. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      1,980
      02-16-2016 04:26 PM #139
      What year is the Passat ? There was a split in 2011 where the factory went back to a single mass.
    15. Member ChunkyPeanuts's Avatar
      Feb 2nd, 2010
      Worcester MA
      3,025
      02-17-2016 05:02 PM #140
      2013
    16. Junior Member
      Jul 7th, 2014
      Charlotte, NC
      26
      '12 Jetta SE
      07-11-2016 11:22 AM #141
      Are these kits still available? I'm going to be in the market for one soon, but they won't pull up on your website. Car is a 2012 Jetta 2.5
    17. Member Pure.Dope's Avatar
      Mar 26th, 2009
      469
      2011 Jetta Sportwagen S
      03-31-2017 03:02 PM #142
      James is legit and full of knowledge. Went above and beyond for me on my 2.5t build. Got me setup w/ clutch+flywheel, pistons and rods. A+++ super duper would recommend.
      //Soon to be PTE5858 2.5t..... //
    18. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      1,980
      Today 01:42 PM #143
