+ Reply to Thread
Results 1 to 2 of 2
Thread: AEB 1.8t - CE1 wiring help
  1. Member vdubbin0.'s Avatar
    Aug 7th, 2004
    G-Rap
    5,601
    MKV R32, 2012 Tiguan SEL 4Motion
    10-10-2008 11:47 AM #1
    Soon to be working on the wiring on my MK1 GTI
    AEB 1.8t swap. I was wanting to use my CE1 stuff cause
    i already have it all, but if its better to go CE2 then so be it.
    I heard it was easy to do, never done it before so i wanna
    do it right the first time.
    I have found lots of info for a AEB to CE2 swap
    just didnt know if its pretty similar or not.
    Here is the info from the 1.8t swap thread...
    AEB swap to CE2 Harness:
    AEB wire color > Description > CE2 fuse box plug location
    T6z - Red Plug
    1. Black/Blue > Coil packs > G1/4 (Black)
    2 White/Black > Diagnostic Port White/Black on Diag. Port
    3 Red/Black > Starter Trigger > F/1 (Red/Black) To Starter
    4 Red/Green > Power for O2 Sensors & Mass Air >G1/8 (Red/White)
    5 Red > 12v for ECU > Y/4 (Red)
    Pin # T10 - Brown Plug Description
    2. White/Yellow Read Switch (L.D.P.)
    4. Blue Alternator Warning Light
    6. Black/Yellow A/C Control Head N/A
    9. White/Blue Vehicle Speed Signal N/A
    Pin # T10m - Black Plug Description
    2. Green/Blue > Tach/RPM Signal To MSD Tach Adapter - White
    3. White/Gray > Oil Pressure Warning >G2/12 (Blue/Black)
    6. Black/Yellow Engine Coolant Level Warning
    7. Blue/Brown > Coolant Temp Gauge >G2/3 (Red/Yellow)
    9. Brown/Red Vehicle Speed Signal
    10. Yellow/Red Leak Detection Pump
    Pin # T10y - Blue Plug Description
    Not used
    Pin # T10z - Yellow plug Description
    2. Green/Black > K-Diagnostic Wire > Pin #7 on Diagnostic/OBD2 port
    6. Red/Blue > Fuel Pump Relay >G1/3 Red/Yellow
    7.
    8. Green/Yellow > Power for Injectors >Z1 (Red/Black)
    also info i found...
    AEB wiring info
    http://johnbaas.dyndns.org/audi/audi_wiring.pdf
    CE1
    http://www.a2resource.com/electrical/CE1.html
    CE2
    http://www.a2resource.com/electrical/CE2.html
    http://forums.vwvortex.com/zerothread?id=2832390
  2. 11-22-2012 05:48 PM #2
    You ever get the ce1 swap done?
+ Reply to Thread
