Fourtitude.com - My first build: 8V 1.8 low compression gonna be Eaton supercharged
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 55
    1. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      83 TD Jetta, 68 Bus, 83 2dr Jetta 16V, 1971 Kawasaki H1 500
      05-11-2008 04:28 PM #1
      Complied the parts for my 1.8 SC build & now have a block getting prepped.
      I will be using an NOS set of Audi turbo pistons. These pistons are notched for squirters but I believe the squirter notches are on the wrong side. I will not be using a squirter block so that is not an issue. I am just wondering if these are still supposed to be installed with the arrow to the front, #1 or pulley side? I don't wanna mess up my new forged low compression pistons...
      Basic build list so far
      2H 1.8L block standard bore
      JH crank
      Audi Turbo 81mm forged pistons.
      G60 rods, new pins seem to be snug, should I have them rebuilt? Have not measured the big ends.
      Solid lifter head, JH or the Eurospec stage 1 I have stashed away... ??
      oil pump?? From the JH or 2H??
      Head gasket?? G60 or JH??
      Also going with the Glyco multi piece Main bearings & got new thrust
      Glyco rod bearings are rifle drilled but the G60 rods are not, no other bearings seem to be avail w/ out holes.
      I will admit this is my first watercooled engine build, any do's & don't do are appreciated. It will have an eaton supercharger attached, should I break it in before the SC gets hooked up?
      This weekend was basically ghetto prep of the block, Intermediate bearings were removed & all freeze plugs. I was going to have it tanked but all the local shops are backed up. I ended up washing the coolant jacket with muraitic acid & it worked well getting all the mung out. It was previously solvent washed & I also again washed it with simple green inside & out. It is now all taped off & a buddy is going to blast the outside to clean up the rust before I paint it. Blasting options are baking soda, glass bead or sand... recommendations here? It will be done open air, outside... I am thinking no on the sand as one missed particle will waste a bearing.
      Finally moving fwd on the 83 2dr Jetta after a long slow winter.
      Modified by vwpieces at 4:42 AM 6-5-2008
    3. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      05-14-2008 05:22 PM #2
      Hey Peter,
      Gonna be a reliable daily driver, pump gas & if I get 10psi I will be more than happy. I do not want to make this too complicated to get set up & running. Already venturing into unchartered waters (for me) w/ the complete build of the engine & then wiring up megasquirt. Actually getting it to start & run will be a joyous day.
      Would you recommend the G60 head gaket or the normal fiber type?
      I have not CC'd the combustion chamber on the heads yet. I will be finished prepping the block this weekend. Glass beaded & all painted up so I can rewash it & start putting some parts back on it.
    4. 05-14-2008 06:38 PM #3
      hi! chiming in here...
      I would definitely go with the g60 head gasket as it lowers compression. and I was wondering why do you want to switch to megasquirt? I would recommend sticking with digifant, but you have to switch to g60 digifant. I'm just recommending it because even though standalone is cool it requires quite a bit of work. thats my two cents. and if i'm missing any technicalities please let me know. g/l with the build.
    5. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      05-14-2008 07:45 PM #4
      I will be getting some help with the MS basics. Originally a CIS car, 83 MK1 Jetta. I have a vast array of OEM connectors & terminals & have made a few harneses from scratch & a Bentley diagram. Nothing too difficult but I made the cooling harness on the 83 TD Jetta as it is TD specific. electrical wiring does not scare me, frustrates me some times but I can usually get it figured out.
      The Audi MC code pistons are originally 7.8:1 CR so I do not think I should be lowering it any more. I still have to CC the combustion chambers & once assenbeled I will check the deck & CC a piston. & I'll have to look up crush thickness of both head gaskets too. Any know off hand to save me some time?
    6. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      05-14-2008 07:48 PM #5
      Oh & just got a call from my buddy that was glassbeading the block. It's all finished & he said he painted it too. Will be doing another coat tonight. NICE... that means it should be good & hard by the weekend & I can get on putting it together.
    7. 05-14-2008 08:23 PM #6
      Good to see it moving foreward!
    8. Member PolishSasquatch's Avatar
      May 8th, 2008
      Detroit
      322
      91F350, 09TDI, 91Fox, 00LS400, 08S8
      05-14-2008 11:05 PM #7
      sorry to jack thread, but to run boost is it ABSOLUTLY NECESSARY to run g60 digi 1? or can it be regular digi 1 or even digi 2??
    9. 05-15-2008 05:02 AM #8
      well g60 digifant is meant for boost and you cant really integrate lets say, a mk1 digi setup with a g60 ecu.
    10. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      05-26-2008 07:54 PM #9
      Block is painted, honed w/ 320 flex-hone, final cleaning is done.
      Bores checked out fine & round. Also checked ring gap & it's fine.
      Started assembly:
      Intermediate shaft bearings
      Intermediate shaft, seals & cover
      ARP main studs
      Main bearings & crankshaft are installed & torqued
      Spins like butter [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Pressed in the ARP rod bolts into the G60 rods the other day too. I will torque them up & check the big ends next. Was in a hurry today & did not get pics to add to my boring post.
    11. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-02-2008 05:09 AM #10
      woohoo pics.
      Bores & low compression Audi turbo forged pistons
      Now we're getting somewhere, mocked up to check alignment of the belts & charger. Do ya like the work bench? Most of the assembly, once it was too heavy to pick up myself, was done inside the cargo floor of the 68 bus. Now it sits on a stand at my buddy's shop.
      Some charger piping. Stock JH head just for looks. Working on the Eurospec solid lifter head. Got some serious porting to do on the intake manifold.
      Spent a couple hours working out a bad cam bearing on the Eurospec head. Some light filing, 400 grit sanding & hand lapping bearing cap on a new cam I had around. It was the bearing on the pulley side that was not happy. After some eyeballing & fixin by hand, I installed the cam. I turned it by the pulley lightly tightening the bad cap. Taking it off several times to oil it up & wipe out the greyed slime. Over all it took me 2 hours until the cam would spin free torqued down. After I felt satisfied with it I used a plastiguage on the bad bearing & it looked swell. Also checked & compared to a good bearing. Plastigauge was the same... success, saved the head. I feel confident to put it back into service. Before the cam would not move at all when torqued. Having a new cam with fresh ground bearing surfaces helped to lap it back into shape.
    12. Member Longitudinal's Avatar
      Nov 13th, 2004
      5,702
      2002 Audi TT Quattro ALMS
      06-03-2008 11:42 AM #11
      You are correct about the Audi oil jet cutouts being on the wrong side. Audi put the galley for oil jets on the other side for the I5 engines. I have built two 8VT engines essentially on this pattern, and both are alive and seem quite content without oil jets.
      Like my Facebook page, Quantum Mechanics, for Audi Fox Quattro progress pics and more.
      https://www.facebook.com/VWQuantumMechanics
    13. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-05-2008 12:53 AM #12
      Quote, originally posted by Longitudinal »
      Thanks for the reassurance. I was wondering if the arrow on top still has the the same rules. I pointed it to the pulley side. G60 rods also got the bumps to the pulley side. Short block spins nice.
      I know from aircooled if you install the pistons backwards you get a funny knock.
    14. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-05-2008 06:14 AM #13
      Nothin new & exciting lately. Been working on the Eurospec head. Head is a stage 1 stock JH valve size & combustion chambers. Did some unshrouding of the exhaust valves & just a tad on the intakes. Slight smoothing of the chamber too.
      No pics of the head work but here is the engine now on a stand.
      Do ya like my Oringinal VW dealer engine yoke?
      A pretty good pic of the mounting adapter for the Eaton Charger to G60 bracket.
      In the back ground is a freshly painted 1984 MK1 Jetta 4dr, custom "duck killer" bill... Not my car.
      Modified by vwpieces at 5:17 AM 6-5-2008
    15. Member Longitudinal's Avatar
      Nov 13th, 2004
      5,702
      06-08-2008 02:47 AM #14
      Quote, originally posted by vwpieces »
      Yup, offset wrist pins. They are supposed to reduce piston rock/noise, but if they are installed backward, that all goes out the window. When I build 8V turbo engines using the 1.7L crank/MC rod/MS piston combo, I follow Audi positioning for the rods (opposite direction of VW rods) and pistons.
    16. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-08-2008 02:27 PM #15
      Sent you an IM to make sure I got my head (pistons) straight.
    17. Member manfredwerner's Avatar
      Jan 29th, 2007
      staten island/brooklyn
      3,576
      2012 2.0
      06-08-2008 08:24 PM #16
      how much is that sc? and also how much is the build costing you so far?
      thanks.
    18. 06-09-2008 02:13 AM #17
      gorgeous. now the pressure is on for my build. finally some motivation!
    19. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-09-2008 01:32 PM #18
      Quote, originally posted by manfredwerner »
      thanks.
      So far I everything sost me about $3500 with the charger.
      The charger package cost $1500 alone & came with all sorts of parts, some that did not go with this setup. Already sold several item like misc parts for the old Autotech Magnacharger, 68mm G60 pulley to recoupe some cash back on the deal.
      That charger alone retails for about $3000 new, you best bet is ebay to find a deal or get a reman from Magnuson or magnacharger.com
      Basic price breakdown:
      Eaton charger & misc pile of parts $1500
      2h Engine 72,000 miles I used the block only $120
      JH Engine 56,000 miles Free but about $50 in fuel to pick it up.
      Main, rod, thrust & intermediate shaft bearings $120
      NOS New Forged Audi pistons set of 4 $220
      G60 rods good used $40
      New JH pump $65
      New oil pan & windage tray $58
      Water pump & housing $60
      Autotech light intermediare shaft pulley $40
      Kent cams adj cam sprocket used $40
      Pile of G60 misc parts, alternator, charger main bracket, injectors & rail, crank pulley, tensioners, Intake, TB & more I am sure $140
      G60 Head gasket $60
      ARP rod, main & head studs... forget, but about $300
      New dizzy $80
      Seals & misc gaskets, $70ish
      G60 alternator cover & Valve cover, got in trade for ECO TD Airbox, aprox value $75
      Custom Cam from TT $250
      Eurospec head Bought it a long time ago for $400
      Autotech HD Springs $85
      TI retainers $105
      New valves & guides gotem a while ago for a different head & do not recall, $150
      Timing belt kit $30
      Another G60 TB from auto with TPS $100
      MK2 water pipe $25
      Misc used G60 Hoses & water pump studs for charger $40
      Lower timing cover & tin & another charger bracket I needed, $30
      Injector seal kits $24
      Digi injector holders for Eurospec head $80
      Misc Stainless fasteners used everywhere possible estimated at $200
      Purchased another pair of pistons while I can get them, just in case... $120
      ABA non AC water pump pulley $30
      stock oil cooler $60
      Why did you have to ask this...
      HMM how bout $4800 estimated soo far & that was done cheap for the most part, no machine shop labor at all. The Eurospec head will be done with much less than 1/2 retail ($2000)
      & I am sure there are parts I forgot.
    20. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-09-2008 01:44 PM #19
      Some new pics. Head, guides getting pressed in & some pics of the bottom end opened up again for the windage tray & pan.
      Head
      Installing new guides
      Bottom end with ARP studs being pointed out.
      Modified by vwpieces at 12:47 PM 6-9-2008
    21. Member
      Jun 17th, 1999
      West Michigan, USA
      5,029
      1998 Jetta VR6 (bone stock daily driver), 1982 twin screw Cabriolet, 94 Mazda B3000 4x4
      06-09-2008 02:01 PM #20
      Gotta love the port sizes on those Eurospec heads
    22. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-09-2008 02:01 PM #21
      Learned some new things, forst installation of the pump & dizzy made the intermediate shaft kinda hard to turn. I repositioned the oil pump this time when I put the windage tray in & also left the dizzy installed. Shaft spins much better now.
      Working in the head now, installed new guides & now they have to be reamed. Gonna buy an adjustable reamer later today. Exhaust seats will have to be ground slightly. 2 out of the 4 exh valves lapped nicely but the other 2 not soo happy. One exh seat has a lip on the inner edge. Once the new guides were in I noticed NONE of the intake valves fit any more. Poped out a used valve from another head & it has the same diameter stem, no fitty either. Measured the exhaust stems & they are 0.001 smaller... Why?? Screw it, getting a reamer anyway.
      Ported the intake the other day too. Not a huge port job but really focused on make a straight line in the rinners. Man there a lot of bumps & curves in a stock intake. Took about 6 hours, using tapered rolls & flap wheels. Gasket matched the openings. No pics right now & I left the intake at my buddy's shop with the engine... maybe tomorrow will post pics of the work.
    23. Member manfredwerner's Avatar
      Jan 29th, 2007
      3,576
      2012 2.0
      06-10-2008 11:36 AM #22
      Thanks for the info on the pricing. now i am afirm n/a motors beleiver...
    24. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-11-2008 11:15 AM #23
      Quote, originally posted by manfredweiner »
      To get equal power from a NA engine it would cost 2X as much.
      Modified by vwpieces at 10:25 PM 4-1-2010
    25. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-11-2008 11:52 AM #24
      Did some working on the head again last night. Turns out I did have a 5/16 Expandable reamer in my bag of tricks. Bouhgt it at a VW show a year or 2 ago for $4.00. It needed some slight tuning of the adjustment pin but it worked well. I reamed the valve guides & fitted the intakes. Learned that production & manufacturing tolerances are not too consistent. Also found a couple dings in the stems of a couple valves. Used a jewlers file & some wet 1200 sand paper to polish up all the stems before fitting them. Having the expandable reamer worked well allowing to size the guide to each valve. Each intake was fitted individually to where it can be lifted, let go & it would fall effortless into the seat. Even though the Exhaust valves fit after the guide installation I still reamed them out to remove any burrs from pressing the guides. I also fitted the exhaust looser than the intakes to allow for more heat expansion.
      I purchased some Autotech HD valve springs... I do not like a couple things about them. Pressure is way too hard in my opinion. The other is the bind of the inner spring to the outer spring. I am considering a hybrid set of springs using the autotech oputers & stock inners. I know a porsche engine builder that has a spring tester & may have him test a stock set, hybrid set & the AT set for comparison. If the hybrid set fall into the middle I will use them mixed. I will also check the bind height to make sure all will be good with the cam lift. My engine is not being built to be an 8000rpm screamer so excessive valve pressure will only wear the components out faster.
    26. Member vwpieces's Avatar
      Apr 20th, 2002
      Allentown, PA
      5,353
      06-12-2008 03:56 PM #25
      Got some flap wheels in yesterday & decided to hit phase 2 porting the intake. Here are some pics of the final product. O used a super thin layer of aviation to get an imprint of head pattern to the intake. Carved a line with an Xacto knife & started to hog the holes to the final size. Total there is about 12-15 hours invested in this intake. It is pretty darn thin & hopefully it will not crack or blow a gasket. One area of concern is #4 lower right for gasket contact surface.
      Anyone have suggestions for a hardening gasket spooge? Not sure silicone or aviation will hold up here under boost.
