Koni Coilovers
22.8 in the front
23.4 in the back
MKV Rabbit Steelies (offset not sure)
No Spacers ( in this picture)
195 65 15's all around
Custom Fenderliner cutting (car did it all by itself by turning)
I'll update when the RS are on
#1
Spring is coming up... time to think about dropping car back to the ground(well, for those of us in the snowy northern part of the continent at least).Thought it would be interesting to get a thread with a picture of people's cars and their stance. When it gets enough posts I will add it to the FAQ.
Please include the following:
1) Picture of your car
2) Brand of Coilover/suspension
3) Front measurement (top of arch to ground)
4) Rear measurement (top of arch to ground)
5) wheel and offset
6) tire and size
7) spacer brand/thickness
8) other info (fender rolling, replacement tie rod ends, etc)If you have more than one setup to contribute list them as seperate entries in one post, and when you make changes rather than removing the old info append another picture and set of info so that we have we have your car with multiple stances.
Please keep discussion to other threads so this one stays neat. Coilover/suspension threads tend to get filled up with clutter quickly.
Edit to make the last point a little more clear: Don't post anything else in here. It will be deleted. Thanks!
Modified by robbyb413 at 11:17 AM 4/18/2008
VAG COM services available, send a PM | Join the VWVortex Folding@Home team... save the world | Current Rides: 2010 S4 Prestige, 1999 TJ 4.0 Sport | Old Rides: 2001.5 A4 1.8TQMS GTRS, 1997 TJ 4.0 Sport, 1990 Corrado g60 StageIV | Lounging in a field with 726 sweater cows
#2
Koni Coilovers
22.8 in the front
23.4 in the back
Suspension installation or other mods for reasonable prices, PM me or Email @ threeztt180@hotmail.com
#3
h&r street sport coilovers
17x7.5 et 43 (iirc)
225/45/17
23.1/4" up front
23.5" in the rear
front fenders rolled
#4
H&R ultra lows
Im pretty sure im around alex measurments
Stock tires and wheels
no spacers
HAVE HEART
#5
koni coilovers
18x8.5
225/40/18
Modified by vins a4 at 11:58 AM 3-15-2008
#6
Please include the following:1) Picture of your car
STaSIS Streetsports3) Front measurement (top of arch to ground)
25"4) Rear measurement (top of arch to ground)
25.5"5) wheel and offset
Oetty RZ 19x8.5 ET356) tire and size
Toyo T1S 235/35/197) spacer brand/thickness
None8) other info (fender rolling)
Fenders rolled
Couple extra 'cause of the Irish in me, arrr!![]()
#7
1) 1999.5 Avant 1.8t Quattro
2) Neuspeed Springs w/Bilstein struts
3) 25.5 Front measurement (top of arch to ground)
4) 25.75 Rear measurement (top of arch to ground)
5) Oettinger RE 18x8 et35
6) 225/40-18
7) No Spacers
8) No moddingWill update when I get the fender measurements
Modified by kenncmiller at 1:39 AM 3-20-2008
#8
VMAXX coilovers
Brock B1 8,5x17" ET13
22.5 in the front
22.6 in the back
205/40/17 Toyo Proxes T1-R
All four fenders rolled..
Modified by brunerune at 7:44 PM 3/20/2008
#9
Brand of Coilover/suspension - FK silverline
Front measurement (top of arch to ground) - 24.3
Rear measurement (top of arch to ground) - 24.6
wheel and offset - Ronal Bolero Et43
tire and size - Goodyear Eagle F1 225/45/17
spacer brand/thickness - FK spacer front 15mm and noname rear 20mm
Modified by Soupie69uk at 11:19 AM 3-28-2009
#10
fk silverline coilovers
23.2 front
23.2 rear
TSW Hockenheim R, 16x9, et 30
nexen 3000, 225/45/16
no spacers
slight rolling of front fenders.
#11
Really bad Pictures. I'll update
KW INOX V1's
22.7 front
23.0 rear (1st picture is 23.6")
BBS RF 3piece
Front 17x8.5 et 20 205/45/17
Rear 17x9.5 et 18 215/45/17
Lug Wrench rolled fronts
No spacers
Never rubbing
<7,000 miles out of directional tires
Modified by 98a4 at 9:46 PM 4-15-2008
#12
2) H&R Coilovers
3) 24"
4) 24 3/4"
5) Ronal Alphards (Merc. SL500)
18x8.5(F) ET.35
18x9.5(R) ET.40
6) BFG KDW2's
215/40 (F)
235/35 (R)
7) H&R 20mm Rear spacers. Final offset in rear is ET. 20.
8) Stock Fenders.
Empty.
#13
temporary stance
KONI coils
24 inches up front
24.8 in the rear
Keskin KT2s
18x8.5 et 45? (not really sure on this set) all around
225/35/18s all around
H&R 5x112-5x130 22mm adapters
fenders rolled and liners cut out
#14
Really crappy photo, I need to go out and take more...
H&R Coilovers
24" Front
24.5" Rear
OEM Sport Wheels
Falken FK452 205/55/16
No spacers (but need some)
#15
5) wheel and offset
6) tire and size
8) other info (fender rolling, replacement tie rod ends, etc)1) ok here
2)K-Sport coilovers
3)24"
4)23.5"
5) 18x8.5 rs4 wheels by Velocity (not sure on offset)
6)225/40/18
7)none used
8)rolled fendersNOTE: The measurements are after lowered more then the picture shows.
#16
Koni Coilovers
24" in the front
25" in the rear
07 Passat 16x7" Steelies +38 offset
Jetta Dub-caps
4mm Spacers in rear
205/55/16 all around
Front fenders are partially rolled
Upper Shock tower was clearanced/bubbled for arm movement
#18
H&R Race springs on RS4 shocks
Front and rear 24"/61mm from the ground to the arches
Wheels: BBS RC 18"x8.5 ET30
Tyres Nankang 255x35x18
H&R 5mm spacers
RS4 arches front & Rear
04 A4 B6 1.8TQ S-Line 190bhp 6 Speed DSMIC
Milltek Exhaust|VMR Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 HFC|Auntbahn88 TIP|N75J|TT MAF|380 inj|
2Do list: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB IV|
#19
[IMG][/IMG]
5) wheel and offset
6) tire and size
8) other info (fender rolling, replacement tie rod ends, etc)1. BANG
2. H&R Coilovers
3.n/a
4.n/a
5. 18x8 et37
6.Yokohama S-drive 205-40-18
7.n/a
8.n/aModified by BLK1.8Turbo at 7:54 PM 5-6-2008
Modified by BLK1.8Turbo at 8:25 PM 5-6-2008
Originally BLK1.8Turbo
#20
vmaxx coilovers
a little under 22.25"
22.5"
2007 mercedes e320 wheels 16x8 et36
205/45/16 blue streak stiletto's made by bridgestone
10mm spacers up front/20mm in rear
front et26 rear et16
Modified by sum1namedjames at 10:03 PM 4-10-2009
Modified by sum1namedjames at 1:07 AM 6/2/2009
Modified by sum1namedjames at 1:09 AM 6/2/2009
#21
bilstein pss9 coilovers
25" gtf rear
24.5" gtf front
oem celebrations 17"x7.5" et43
225/45/17 falken 452's
no spacers, but soon to have 15mm font and rear
Modified by alexroyal816 at 4:06 PM 4-3-2009
#22
1) Koni Coilovers
2) 23.75
3) 24
4) Mercedes wheels made by Ronal 18X8.5 et 44
5) 225/35/18
6) H&R 15 mm Spacers Rear, 10 mm Front
no fender rolling no rubbing
#23
H&R street sport(purchased from Lazer Viking..same as in his pic)
F 22.5
R 23.0
RS6 Reps 18x8 43 or 45(i forget)
225/40 18 Kuhmo ASX
No spacers
#24
ST suspension coilovers
18x8.5 et 25 in the rear 23" gtf
18x8.5 et 30 in the front 22.75" gtf
Modified by Lazer Viking at 10:12 PM 6-23-2009
#25
18x8 tsw holstens.
205/40 s-drives
front et28 aprox 23gtf
rear et 15 aprox 23.25gtf
vmaxx coils
#26
Car # 118x8 rs4 reps
235-40-18 nexens
15mm spacers front & rear
KW V2 C/O
Car # 217x8 OZ Ultraleggera's
225-45-17 Potentza's
Stais Track Sports
#27
1) ^^^
2) AK coils
3) need to get a proper level bit of ground
4) as above
5) standard avus just now
6) standard also
7) no spacers
#28
Not sure I would call it stance, but oh well.1)
2) ST coils
3) 24 5/8"
4) 24 5/8"
5) 17x7.5 et 45..43??
6) 225/45 falken 912
7) none
8) none
#29
1)2) ST Coils
3) 22.5
4) 22.75-23ish
5) 18x8 not sure on offset
6) 205/40/18 S drives
7) 15mm spacer in the rear, nothing up front
8) whole front end was OEM with 200k when i changed it recently.
Who knows...
#30
1)2) st coils
3) 23.5
4) 23.75
5) lorinser lm6 18x8.5 et35
6) 225/40/18 capitols
7) no spacers
8) semi-rolled fenders.....piped![]()
Modified by fbm93 at 8:04 PM 12-6-2009
-Wes
germansdoitbetter.comWhat was this!? A car show for ants!? Those cars need to be a least...3 times that big!
#31
Daytona Rial
Et30
18x8.5 and 18x9
225/40/18 all around
Faulkin 512's23 inches fender to ground
R32R1 "whore-tex.com the volkswagen fappers enthusiast website"
#32
Tein S lowering springs
24.5
24.5
Stock 15"
205/60R15
#33
vmaxx coilovers
22.5"
front et26 rear et16this is sexy
Modified by sum1namedjames at 1:09 AM 6/2/2009[/QUOTE]
#34
Getting there...1)
2) ST coils
3) 24"
4) 24 1/4"
5) 17x7.5 et 45
7) 25mm H&R rear, 17mm Fk front
8) front fenders rolledI will have better pics soon with new/different tires.
here it is:
3) 23 3/8"
4) 23 3/4"
6) Nexen N5000 215/40/17
and a better shot of the offsets:
Modified by .Mad Hatter. at 11:43 AM 2/7/2010
#35
- Koni SS Coils
- F: 23 1/2" R: 23 3/4"
- Phaeton Challenge: 18x8.5 ET45
- BF Goodrich Sport: 215/35
- H&R Spacers: F:15mm R: 20mm* Lowered another 1/2" to 23 1/2" after photo was taken.
Thanks to Lazer Viking for having a perfect stance an me just replicating it
Modified by CFK at 7:26 PM 5/2/2010
WTB: BBS E49/50 4x100/108 Centers
