Fourtitude.com - Intake Flap Motor Recall
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 68
      Jul 6th, 2006
      1,743
      2012 VW GTI 4dr Sunroof/Nav
      02-25-2008 11:48 AM #1
      From my local VW tech:
      On Feb 21st VW just announced the Q3 recall. This recall involves checking the intake runner flap motor and performing basic settings on the motor. If BS performs OK, then there will be an update on the ECM.
      If the BS test fails, you get the update and a new motor.
      The TSB is 01-08-08.
      Looks like APR, Revo, and GIAC will have to update their software yet again.
    3. Member thenew3's Avatar
      Jun 18th, 2006
      Carmel, CA
      1,030
      2008 Passat 3.6 4motion Wagon, 2007 Passat 2.0t Sedan
      02-25-2008 11:49 AM #2
      Can anyone get a PDF of this TSB? or more info on which vehicles it affects?
      2008 Passat 3.6 4Motion Wagon Mine RIP Totaled 4/23/2013
      2007 Passat 2.0t sedan Wife
      2007 Passat 3.6 4Motion Wagon Mine, Lemoned
    4. 02-25-2008 11:50 AM #3
      wonderful news - my mom's car keeps having this issue.
    5. Member
      Jul 6th, 2006
      1,743
      02-25-2008 11:52 AM #4
      There is no vin range...it's all vehicles 06-08 according to him. Call your local dealer and provide your vin to find out if you're affected before you take it in just in case.
    6. 02-25-2008 11:52 AM #5
      your tech is wrong it's not a recall its a "required vehicle update" which is different than a recall in the sense that people will not be notified they will just check cars at the dealer and if need be do the 03 update [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Jul 6th, 2006
      1,743
      02-25-2008 11:53 AM #6
      My apologies...I must have misunderstood.
      Either way, modded or not...this is a REQUIRED fix and will be performed if needed.
    8. Member rbradleymedmd's Avatar
      Feb 23rd, 2007
      Columbia, SC
      4,132
      B6 Passat
      02-25-2008 12:00 PM #7
      I finally get my PCV fixed, and then this code pops up yesterday. Now, hopefully this will fully cure the issues. Is the new updated SW gaurenteed to wipe all aftermarket SW out?
      Chapter 11 Dubs
      Quote Originally Posted by Joel@Eurojet
      Dazzle them with brilliance, don't baffle them with Bull****.
    9. Member
      Jul 6th, 2006
      1,743
      02-25-2008 12:01 PM #8
      Yes...the procedure is the same as the OY recall and will remove your aftermarket software.
    10. Member rbradleymedmd's Avatar
      Feb 23rd, 2007
      Columbia, SC
      4,132
      B6 Passat
      02-25-2008 12:10 PM #9
      Thanks NG. Man that sucks it removes the SW. Now that I moved, I live at least 2 hours away from my GIAC dealer. Is there anyway this could contribute to my 2-3 psi loss? I have replaced PCV (upgraded to 4 checkvalves) and run the Forge DV...as well as cleaned (with rubbing acohol) all hoses and replaced all clamps throughout the Intake System (no leaks anywhere). Anyone got any thoughts on this? Sorry to jack NG, if you want I will post in different thread (just wasn't sure if this could be the culprit or not).
      Chapter 11 Dubs
    11. Former Advertiser
      Jan 9th, 2003
      2,732
      02-25-2008 12:11 PM #10
    12. Member
      Jul 6th, 2006
      1,743
      02-25-2008 12:22 PM #11
      This should not affect boost pressures...here is his explanation of what it actually does...
      "Your intake has a flap in it. This flap moves so air can flow faster depending on rpm and engine load. The motor that moves this flap is also a position sensor. This motor/sensor is a POS and fails often on the 2.0T's. After vw found a problem and everyone had a failing sensor, they made the sensor better...but it still failed. Then they said oops, the sensor was good all along, the programming was bad luhlz...Recall..."
    13. 02-25-2008 12:33 PM #12
      So will this show up on the VAS just like a regular update ?
      Or do we have to go "looking for it" ?
    14. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      23,422
      indeed!
      02-25-2008 12:35 PM #13
      Quote, originally posted by Robin @ Revo Technik »
      This is the new "OY". It's S0040
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    15. 02-25-2008 12:42 PM #14
      Here is the one I have...
    16. Former Advertiser
      Jan 9th, 2003
      2,732
      02-25-2008 12:47 PM #15
      Thats the exact bulletin I read this morning, thanks for posting that!
      And LOL at doing that intake motor flap in 70 minutes...
    17. 02-25-2008 01:13 PM #16
      Dang... I wonder how much this would set me back, as I am chipped. I guess I'll just cross my fingers and hope I don't have to deal with this anytime soon.
      2007 GTI Pkg1; 18" Huffs; APR Stage 2; AWE DP w/ Metal Cat; Neuspeed P-Flo; Eurojet FMIC; Eurojet Turbo Discharge Pipe; A3 TB Pipe; OEM Piston DV; BSH Stg 2 PCV w/ Catch Can; NGK BKR7EIX Plugs; AWE Boost Gauge; ECS Motor Mount Insert; FFE Shifter Bushings; 42DD Shifter Cable Bushings; Neuspeed Sport Springs; Koni FSD Shocks; Neuspeed Rear Sway Bar; Smoked Corners; Window Tint; Tinted Tails; 3M Clearbra; Infinity BassLink II Subwoofer
    18. 02-25-2008 01:39 PM #17
      how does the dealer "check the ecm to ensure it has not been tuned"?
    19. Member
      Jul 6th, 2006
      1,743
      02-25-2008 01:39 PM #18
      Problem is you'd have to sign a waver or something saying you're chipped when you bring it to the dealer for anything else me thinks.
    20. 02-25-2008 01:51 PM #19
      Quote, originally posted by mwwVW »
      they don't they just flash the car and couldn't care if you are chipped or not, if you choose to not have the flash down you sign a waver telling vw you have a tuned ecm the tech sends it to voa and they put it on file that your car has a tuned ecu
    21. Member 1.8tjettaman's Avatar
      Aug 3rd, 2003
      Norcal
      1,259
      2006 GLI
      02-25-2008 02:40 PM #20
      So basically if you keep your mouth shut no one will ever know......
      If the glove doesn't fit......you must Acquit!!!
    22. 02-25-2008 07:43 PM #21
      What happens if you have the upgraded fuel pump? I was about to get one. Will it damage my engine to drive from the dealer back to my tuner?
    23. Former Advertiser
      Jan 9th, 2003
      2,732
      02-25-2008 07:49 PM #22
      It will be fine to drive until you get reflashed by your tuner again.
      Rereflashed?
    24. 02-25-2008 07:55 PM #23
      Rereflashed?
      if you look on the tsb it only says it is for the B ecu's, meaning at this point in time us 2007 and newer guys are safe....but as for 2006 guys you all get robin's rereflash.....lets just hope their is never going to be a rerereflash
    25. Member
      Aug 24th, 2003
      Green Bay, WI
      1,518
      2016 Jetta Sport Auto
      02-25-2008 08:55 PM #24
      I've already had my intake flap replaced under warranty. I wonder if they will leave me alone? I've had no CEL's since the replacement.
    26. 02-25-2008 09:24 PM #25
      OK, I don't have a MIL on, but I do have the software revision 8EO910115P that calls for a flapper motor replacement (without checking for chipped software if I read the TSB right)
      So it needs to "fail" (pull the plug?) first to get a replacement?
