Fourtitude.com - Bad Coil Packs? What are the symptoms
    Results 1 to 25 of 26
    1. 01-16-2008 11:59 PM #1
      So I was driving my car tonight kinda hard (not that bad) on the highway, my Rpms were in the 3500-4000 range for a good amount of time.. After i get off the highway the car is running rough, sounds like a wrx. I know people on this site say a car sounding like a WRX is most likely the coil packs.
      My question is... What causes the coil packs to go? Is it just coincidence that they went after I was getting on the car a little? And how can I determine which coil pack out of the four is the bad one or one(s).
    3. 01-17-2008 12:07 AM #2
      Pull them all and if one is bad the metal may appear to have a brownish tint. (I have no idea why that happens but it does)
    4. 01-17-2008 12:11 AM #3
      Some of my symptoms were black smoke coming out of my exhaust!
    5. 01-17-2008 12:12 AM #4
      there is no 1 reason why the go, they just do. they are an electrical component. maybe they were designed poorly. all i know is i have a set of 4 in my trunk for just that occasion.
    6. 01-17-2008 12:14 AM #5
      and the car sounding like a WRX is a pretty good symptom that its a bad coil pack right?
    7. 01-17-2008 12:20 AM #6
      blakc smoke is a sign of it running rich. This might mean that the fuel wasn't being ignited. do you have a CEL right now?
    8. 01-17-2008 12:28 AM #7
      I do, but its been on for a little bit
    9. 01-17-2008 12:30 AM #8
      go to advanced auto or something and have the codes pulled and see what you come up with.
    10. Member jasonsp6's Avatar
      Sep 7th, 2003
      Orange County, NY
      537
      00' TDI Golf
      01-17-2008 10:56 AM #9
      Typically your engine will be running rough. You usually can head/feel it missing along with degraded performance. Your CEL light sometimes will flash indicating a misfire issue.
      The easiest way to determain which coil pack is bad is using VAG-COM.
      Without VAG-COM you can remove each coil pack and look for stress/ burn marks. If none of them show physical signs of damage, pull and read the spark plugs.
    11. Member Custom158's Avatar
      Sep 3rd, 2006
      Manchester, CT
      1,409
      2010 VW GTI 2012 Ducati Monster 696
      01-17-2008 03:08 PM #10
      if you dont have a VAG-COM, just a generic OBDII scanner and you get a misfire in a cylinder, swap the corresponding coil with another one and see if the CEL jumps with it.
      either way, there are a thousand reasons why you could be running lean, but relatively few places that could be the cause of it. its not getting burned, so it definitely sounds like something with the plugs or the like.
      2010 CSG VW GTI 6MT - APR K04 v3.1
      Facebook | Micro CAN VAG-COM
    12. 01-17-2008 05:41 PM #11
      is it bad to drive with bad coil packs? I only ask because I have other coil packs at my parents house, and I wanted to put those in and see if i fix the problem, also my friend with a vag com live up near my parents. Its about a 45 min drive. What do you say?
    13. 01-17-2008 08:37 PM #12
      dont. you will be dumping raw fuel into your cat. dont drive on it
    14. 01-18-2008 02:52 PM #13
      I pulled them and they all seemed to be alright, the only difference I seemed to notice with one of them was all the way inside on the metal that actually touches the spark plug was either black or brown, either way I couldnt see it, where was on the other 3 it was clearly visible.
    15. 01-18-2008 02:56 PM #14
      Quote, originally posted by icefox »
      Its like that skit on Seasame street - "Which one of these is not like the others?"
      Sounds to me like you've narrowed down which one is bad.
    16. 01-18-2008 02:58 PM #15
      Haha thanks man, I really hope thats the issue, Ive had a few issues with the axles on this car and I jsut spent alot of money replacing those, then the week i get the car back this happens!
    17. 01-18-2008 03:00 PM #16
      of all the problems you could have I think coilpacks are pretty far down the list regarding expense and PITAness.
    18. 01-18-2008 03:06 PM #17
      Oh i know Im saying im grateful its the coil packs, and I hope its only those because they are cheap.
    19. Member tamorgen's Avatar
      Dec 1st, 2003
      Columbia, MD
      1,517
      2001 VW Jetta Wolfsburg 1.8t (RIP), 2007 VW GLI 2.0T, 2013 Touareg V6 TDI Exec
      01-18-2008 03:57 PM #18
      Coil packs most often go if you are driving a 1.8T
      Seriously, I've had a number go on me, and it's normally under high acceleration. I kept replacing one here and there with the Bremi "R" revision (AWW engine), or whatever was the newest at the time. Problem was they kept poping out and going bad. Finally, when two went bad at the same time, I changed all 4 to the Hitachi "E" revision normally, AWD engine) and bolted them onto the valve cover. I haven't had an issue since then.
    20. Member jasonsp6's Avatar
      Sep 7th, 2003
      Orange County, NY
      537
      00' TDI Golf
      01-21-2008 12:12 PM #19
      I went through 7 coil packs in three years on my 2002 AWP code engine.
    21. Member Mr.V-Dub's Avatar
      Jun 4th, 2007
      Brigham, Utah
      1,596
      Jetta Beast
      01-21-2008 12:57 PM #20
      That=100% coilpack. I've only blown 7 or 8 in a year..
    22. 01-21-2008 07:32 PM #21
      Great to know. Thanks man
    23. Member Mr.V-Dub's Avatar
      Jun 4th, 2007
      Brigham, Utah
      1,596
      Jetta Beast
      01-22-2008 08:34 AM #22
      [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. 01-22-2008 09:54 AM #23
      I'm certain this is not a VW approved diagnostic technique, but it works. With the engine idling, pull a coil off the sparkplug. If it is good, you will hear a pop, pop, pop sound of the spark on each ignition cycle. No pop= bad coil.
    25. 01-22-2008 11:35 PM #24
      Ill give it a try, ill try anything, I tried replacing the coil that i thought was bad, but it didnt work, I have to spend more time on the car tomorrow
    26. 01-23-2008 12:17 AM #25
      Quote, originally posted by r0ach »
      that's not necessarily true in all cases. i had two of the brand new version "R" go out on me after 2 months! they looked brand new!! [IMG]http://*****************.com/smile/emthdown.gif[/IMG] [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
      Edit:
      Please replace them all with Hitachi bolt-down coilpacks found on http://www.ecstuning.com and save whatever good coils you have in your trunk [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by RvGrnGTI at 9:19 PM 1-22-2008
