Fourtitude.com - MKIII Golf VR6 Swap Partts list
    Results 1 to 6 of 6
    1. 01-12-2008 09:31 PM #1
      I know this topic has been covered, however whenever you need something you can never find it. I found plenty on MKII VR6 swap info but not enough covering the MKIII.
      Parts needed:
      VR6 wiring harness
      VR6 ECU
      VR6 motor mounts
      Heater hoses
      Coolant Hoses
      CCM or O2A transmision
      CCM or O2A transmision mounts
      CCM or O2A axels
      CCM or O2A shift linkage
      Are the speedometer and tachometer cables the same?
      Are the rack and pinions the same?
      Feel free to let me know of any changes needed to be made to the list.
      Modified by MKIIIGOLFVR6 at 6:35 PM 1-12-2008
      Modified by MKIIIGOLFVR6 at 6:36 PM 1-12-2008
    3. 01-12-2008 09:38 PM #2
      O2A Transmision codes and gear ratios
      ATA 3.778 2.105 1.345 0.971 0.795 3.684 Corrado G60
      AGC 3.778 2.105 1.345 0.971 0.795 3.944 Passat 16V
      ASD 3.300 1.944 1.308 0.971 0.717 3.944 Passat 16V
      AYL,AYK 3.778 2.118 1.429 1.029 0.837 3.684 Corrado G60, Passat 16V
      CCM,CHN 3.300 1.944 1.308 1.034 0.838 3.389 VR6 Passat, Golf/Jetta III
      CDM 3.300 1.944 1.308 1.034 0.838 3.647 VR6 Corrado
      CHA 3.778 2.118 1.360 0.917 0.717 3.944 TDI Passat
      CNL 3.778 2.118 1.458 1.029 0.837 3.684 2.0L 8V Passat
      CES 3.778 2.118 1.429 1.029 0.837 3.684 Passat
      CGY 3.778 2.118 1.458 1.029 0.837 3.684 Passat
      CAW 3.778 2.118 1.458 1.034 0.838 3.647 Corrado
      Aug 7th, 2004
      Rockaway,NJ
      7,830
      94 golf
      01-13-2008 12:46 AM #3
      Quote, originally posted by MKIIIGOLFVR6 »
      Parts needed:
      VR6 wiring harness
      VR6 ECU
      VR6 motor mounts
      Heater hoses
      Coolant Hoses
      CCM or O2A axels
      you need a 02a vr6 shifterbox.
      you dont have to do the vr6 mounts.
      if you want to keep 4 lug and your car is manual trans you can leave all the suspension and axles. if you want 5 lug you must change brakes, control arms, swaybar, brakes, tierods, axles.
      you will need a mk3 clutch master cyl bracket and clutch master and slave cylinders and lines all from a mk3.
      you will need VR6 rad and fans from a mk3.
      you will need a VR6 cluster and cluster harness.
      All VR6 trans are 3.38 R+P CCM except the corrado CDM which has a 3.68.
    5. Junior Member garyst's Avatar
      Jul 1st, 2007
      Pennsylvania
      93
      1996 Cabrio, 2000 Cabrio
      02-11-2008 05:41 PM #4
      I have a MK3 Cabrio 2.0L and I want a VR6 swap. I was looking for a parts lists so I have some doubts about it?
      Do I need the fuse box?
      I found somwhere that I need 2 change:
      -gas pump
      -water pump
      -alternator
      -distributor
      -starter
      is that true?
      anything else?
      thnks
      Aug 7th, 2004
      Rockaway,NJ
      7,830
      94 golf
      02-11-2008 06:38 PM #5
      fuse box no. the waterpump, alternator, and starter must be from a vr6. most vr6 are coilpack
    7. Member geoj's Avatar
      Nov 5th, 2006
      11,592
      07-03-2009 05:38 PM #6
      From the dead...
