Fourtitude.com - Duratec V6 vs Mazda KL series?
    Results 1 to 25 of 34
    1. Member HerrGolf's Avatar
      Nov 30th, 2002
      Columbus, Jugoslavija
      5,850
      2000 Civic D16Y7
      11-28-2007 08:43 PM #1
      Who made a better engine?
      It seems that the Duratec is found in more vehicle lines and was advanced for its time.
      On the other hand, the Mazda KL (in 1.8, 2.0 and 2.5 (warm cam and hot cam)) forms seemed to employ higher tech, like a two piece engine block and a Porsche inspired intake. Plus, it sounds really good in the Ford Probe.
      Which one is the better engine and why?
    3. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 12:21 AM #2
      Quote, originally posted by HerrGolf »
      I was under the impression that the KL motors had variable intake geometry before Porsche did; at least commercially?
      Edit: Porsche first used Vario-Ram starting in 1992 for their Euro-spec RS motors in the 964. Not sold in the US. Vario-Ram was featured on the 270 HP 1995 911 (993). This was bumped to 282 HP in 1996 with the addition of Vario-Cam.
      I've found the KL to sound a bit more exotic than the Duratec, and feel more responsive; even if the Duratec ultimately is a more powerful motor. (Part of the Duratecs lethargic feel is due to emissions control calibrations that the KL didn't need to meet earlier in the 90's)
      Modified by JrodVW at 12:31 AM 11-29-2007
    4. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 12:28 AM #3
      And for those in the lounge who are unsure what the KL series was in
      1993-2002 Mazda 626
      1993-1997 Mazda MX6
      1993-1997 Ford Probe GT
      1995-2001(2002??)Mazda Millenia (non S)
      All with the 160/164/170 HP 2.5 Known as the KL-DE or KL-03. The Hot motor was the KL-ZE that was more than just a hot cam. The upper intake was completely reconfigured pretty extensively. Those motors were good for another 30 HP out of the box.
      The 1.8 V6 was found in the Mazda MX-3 GS.
      The VRIS - Variable Resonance Induction System was similar to the intake system found on the Corvette ZR-1 and later found on Porsches in the form of Vario-Ram(not to be confused with Vario-Cam which is variable valve timing). A solenoid in the intake manifold would open at a prescribed RPM, switching the intake to a different set of runners for improved high RPM breathing.
      You could really feel the change over point; yet these motors often ran out of guts around 6300-6500 rpm due to restrictive heads. They were redlined at 7000 RPM; would freely spin past that, and made an exotic sound that would make Corrado owners jerkoff in the corner.
    5. 11-29-2007 12:34 AM #4
      The KL sounds like crap in Millenias [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
      Does sound good in the Probe though [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 11-29-2007 12:36 AM #5
      the Duratec is a good motor.. though i find it a bit noisy... un refined.
      lets not forget what motor Noble uses
    7. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 12:36 AM #6
      VRIS Further Explained.
      During times of resonance, the vibrating columns of air (which, though moving, still can support a standing wave) can actually help charge the cylinders. A vibrating column of air has dense sections and rarefied (low pressure) sections. If the standing wave is just right, a dense section of air meets the valve just as it opens. The denser air pours into the port, moreso than if resonance (and thus this standing wave) wasn't happening. The effect is a very mild "supercharging".
      But the engine RPM is always changing. If there was only one runner length, there would only be one resonance point. Mazda makes the manifold like a flute that can resonate at several wavelengths by making the runners have variable effective lengths. They do this by using butterfly valves in the manifold to direct air a "long way" or a "short way" (#2 is primarly responsible for this). Closed, the path is "long" and the primary resonance frequency is low. Open, the path is short and the primary resonance frequency is higher. By further changing the frequency in each surge tank (by opening or closing #1 valve, which exposes the each bank to the others' intake pulses, effectively doubling the frequency each surge tank sees), they manage to get several points at which good standing waves are set-up through the RPM band.
      In the KL03, the VRIS (variable resonance intake system) plates are controlled by the PCM, which is looking at engine RPM and loading (throttle angle) to know when to open the valves. #1 opens at 3250, which doubles each surge-tanks' frequency. #2 opens at 4250 which then shortens the average path length by 1/2. At 6250, both valves close.
      This 6250 point is a bit of a let down. The natural tendency would be to further shorten the path length but the realities of aluminum casting (driven by packaging and cost concerns) rears its head: there's no provision to make things even shorter. The only recourse they have is to revert to the longer path and lower frequency and rely on the 2nd-harmonic to provide a reduced-but-still-effective ram effect. It's a compromise and one of the things I dislike about the KL03 manifold.
      The North American I4 does not have this system, just the V6.
      BTW, people who get a KLZE but who don't upgrade their PCMs are getting hosed: the KLZE, with it's markedly different manifold, has different resonance points than the KL03. The PCM doesn't know this and switches the valves thinking it's an '03. Meanwhile, the ZE manifold never really has a chance to do its resonance thing properly because the PCM is stupidly flipping the valves at the wrong times.
      Also, people who remove or "tie" their VRIS are also hosing themselves. By disabling this feature, they're removing resonance points from the RPM band. Engine torque will suffer in the affected RPM areas and peak power will not climb. (Well, if someone completely removes the #2 valves & shaft, I suppose a bit might be gained from the removal of the restriction in the 4250-6250 range, but it won't be a huge gain and output will suffer everywhere else...)
      Its absolutely nothing like VTEC. It IS however, very much like quite a few resonant tuning systems used by nissan, porsche and bmw (to name a few). Adjustable cam timing and resonant air tuning are very very different.
      For even geekier info visit http://www.geocities.com/mikey...s.htm
    8. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 12:37 AM #7
      OK I'll stop I swear.
      Here is a Miata with a KL V6 with individual throttle bodies as well.
      http://youtube.com/watch?v=toughTZ9PIw
    9. Senior Member JustinCSVT's Avatar
      Oct 3rd, 2004
      Atlanta, GA
      20,999
      2015 VW GTI 5-door
      11-29-2007 12:40 AM #8
      Those were actually Duratec features. IIRC, the original Duratec designed by Porsche was 2.7L and made around 250hp.
      Todras is on here and knows way more than me about the engine. I'll vote for the Duatec because mine was an absolute blast to drive and was tough as nails for the 35K miles that I had it.
    10. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 12:48 AM #9
      Quote, originally posted by JustinCSVT »
      Cosworth had a hand also [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      If you can; track down an article called Night of the Living Iguana by John Philips from Car and Driver. It was from 1995 (IIRC) and was about flogging a prototype high output Contour at the 24 hour Nelson Ledges race (to become the SVT)
    11. 11-29-2007 12:50 AM #10
      The SVT massaged duratec sounded sweeet can;t knock it
    12. 11-29-2007 01:02 AM #11
      why the hell are you guys discussing low-performance economy car motors?
    13. Senior Member JustinCSVT's Avatar
      Oct 3rd, 2004
      Atlanta, GA
      20,999
      2015 VW GTI 5-door
      11-29-2007 01:03 AM #12
      Quote, originally posted by lowerbacktattoo »
      Because we can...
    14. Banned
      Mar 9th, 2001
      13,716
      11-29-2007 01:04 AM #13
      What are you talking about troll? The KL was one of the most advanced V6 motors when it became available and was never marketed as an "economy" motor.
      The Duratec is also a fantastic design. Neither are boring, cookie cutter ho-hum V6's.
      Get the **** out and go troll some where else. You didn't even read a damn word any of us posted; you just saw Mazda and Ford = Not German; let's poo!
    15. Member staggered mk4's Avatar
      Sep 11th, 2003
      Bessemer City, North Carolina
      5,068
      '00 Jetta GLX VR6, '86 M-B 190E 8v
      11-29-2007 01:47 AM #14
      Quote, originally posted by Impeccable »
      Amen. Miss my '94 GT dearly.
      "The hype of a wheel is not a derivative of its price... The cost is a derivative of their hype." M. Burroughs of Stanceworks
    16. Member GiacGtiAgain's Avatar
      Nov 8th, 2006
      Commack, NY
      12,552
      E46 coupe
      11-29-2007 01:58 AM #15
      My gf has a 2.5 litre duratec in her 5 speed 99 cougar. it feels sluggish, partly due to a ridiculously heavy flywheel and poor gearing. however, with just an intake, the thing makes some glorious noises at WOT above 4000 rpm.
    17. 11-29-2007 02:02 AM #16
      Wow, what an idiot.
      You might want to rethink your time here. We're not exactly the 16 year old amateurs you hang out with on the street racing boards....
    18. 11-29-2007 02:03 AM #17
      My vote is for the DUratec, only because of the flexibility of it. You can put one in a Focus with some degree of ingenuity. The SVT parts on the 2.5 SVT Contour mean that with some creativity, you can take a 3.0L block out of a Taurus and bolt it, and the SVT parts, together in a lighter car like a Cougar and have an absolutely screaming monster on your hands.
      I am still playing around with the idea of turning the Focus into a V6. It would solve every problem I have with it.
    19. Member Viss1's Avatar
      Dec 1st, 2003
      5,881
      2005 Outback Wagon, 1973 Corvette
      11-29-2007 10:01 AM #18
      Quote, originally posted by JrodVW »
      FWIW the Duratec also had that feature.
    20. Member Merc-MarkO's Avatar
      Nov 21st, 2001
      Great State of Oregon
      19,202
      a '98 [on life support] and a '07
      11-29-2007 10:35 AM #19
      lol. trampstamp.
      Where is Kyron ??? http://www.bringkyronhome.org/
      Support our troops, bless the fallen.
      Quote Originally Posted by genjy View Post
      Yes, there is a high chance that the tractor trailer was the one going 160MPH, not the Porsche GT2 RS.
    21. 11-29-2007 08:53 PM #20
      Yeah, you're 30 year old amateurs who make 25k a year and love miatas only because you can afford them, all the while realized they're crappy cars.
      Anyway point is you're talking about low displacement motors that used previously existing technology and were placed into dull cars.
    22. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      73,185
      88 F150, 04 RX8, 96 T&C LXi
      11-29-2007 08:58 PM #21
      The great thing about internet forums- you don't have to participate or even read threads that you are not interested in. Considering this thread has a very accurate thread title, it does raise the obvious question of why you even posted if you think these motors are somehow unworthy of discussion.
      On topic- didn't the Noble M400 use a twin turbo duratec 3.0 making 425 hp in stock form? While the 3.0 may be lower tech, it definitely seems to have been built (Ford) tough.
      I think the main issue with the Mazda KL series engines is that they really needed to rev to make power, and there were expensive distributor failures. But that may have affected more than just the KL engines.
      Modified by BRealistic at 6:06 PM 11/29/2007
      "Sometimes, I have a sudden urge to fart on this chair."
    23. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      19,685
      Current: Audi S4, B9 Allroad, Porsche Boxster S, Ford F-150 FX4 4x4
      11-29-2007 09:18 PM #22
      Quote, originally posted by BRealistic »
      Actually, the KL motors were always praised for their friendly torque curves. Power fell off well short of redline and they were better short-shifted.
    24. 11-29-2007 09:19 PM #23
      Since we're making generalizations...
      You're a 27yo douchebag with the dreams of a pedophile without the charm who makes plasma donations every Thursday in order to maintain residence in the attic room of the local crackhouse.
      Isn't this fun? I [IMG]http://*****************.com/smile/emlove.gif[/IMG] intarwebz!
    25. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      19,685
      11-29-2007 09:20 PM #24
      Oh, I might add that Duratec's have a nasty habit of insta-ploding if you take it to 7k or beyond, but a KL could rev to 8k all day (but doesn't make power there, stock anyway).
    26. Member Jetty!'s Avatar
      May 9th, 2006
      18,584
      2007 VW GLI, 2004 Honda S2000
      11-29-2007 09:26 PM #25
      What car are you so proud of that you don't even care to share?
      By the way, I don't care for this topic too much but never realized how good that Mazda engine sounded.
      Modified by Jetty! at 9:29 PM 11-29-2007
