Fourtitude.com - NO BENT VALVES WITH TIMING BELT BREAK?
    Results 1 to 21 of 21
    1. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      77std, 84 cab, 92 passat, 92 jetta, 99 A6 avant, 01.5 1.8TQM, 99.5 1.8TQM
      01-25-2007 09:50 PM #1
      i bought this car as is with a broken timing belt, but the belt did not break, it just stripped the teeth off at the crank, the belt was still intact but the teeth were all gone from the belt at the bottom..., the question is, is it possible to have no bent valves with a situation like this? i am looking at the valves with the cams out and all the valves are setting on the seats... i mean on the seats, not off at all. the pistons dont have any marks or scraches at all... and all the valves sit flush...? what is going on here engine bottom end rotates fine... help me out here
      part outs & repairs on Instagram as patsspeedshop
      VAG Parts & Service since 2001 $65/hr labor
      Pat's Speed Shop Euro Parts & Service
    3. Member Scuba2001's Avatar
      Jul 15th, 2002
      Greenville, SC
      11,269
      2014 VW Jetta SportWagen 2.5L
      01-25-2007 10:23 PM #2
      Its possible, but in most cases with these interface engines, there is USUALLY some kind of valve damage. Check things closely from all angles.
      Hopefully its not too bad. If the belt broke/stripped at low rpms, its possible that there isnt any damage at all. Just really depends.
      Scuba Steve
      Certified Audi Technician
    4. Member Greengt1's Avatar
      Aug 27th, 2006
      Lansing IL
      3,741
      92 Monty Green GTi 16vt
      01-25-2007 10:27 PM #3
      The same thing happened to me before.. The teeth stripped off at the crank. I put a new belt on just to make sure............and tap tap tap is all i heard. bent valves but the car still ran.
      Plenty of parts for sale!
    5. 01-25-2007 10:36 PM #4
      The situation you described with the timing belt usually bends valves but not always, sounds like you may have just gotten lucky. It's possible the valves are very slightly bent and just not readily visible to the naked eye so, since you've got the head off, turn the head upside down, level it off and fill each combustion chamber with solvent, if any of the valves are bent, the solvent will leak into the port rather quickly.
    6. Member Greengt1's Avatar
      Aug 27th, 2006
      Lansing IL
      3,741
      01-25-2007 11:23 PM #5
      This looks hot!
    7. Member Scuba2001's Avatar
      Jul 15th, 2002
      Greenville, SC
      11,269
      01-25-2007 11:43 PM #6
      Quote, originally posted by Greengt1 »
      This looks hot!
      I need to find pictures of valves from the 1.8L. Those looked like S's
      Scuba Steve
    8. 01-26-2007 12:01 AM #7
      ouch-40k tb service no joke
    9. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      01-26-2007 06:11 PM #8
      yeah i tried the solvent in each chamber idea, yeah they are all bent just enough not noticable from the naked eye but a slow leak from 3 of the 4 cylinders were leaking.... so i need to buy 12 more valves.... thought id only bent 4, i should have done this before... u live and learn... thanks vortex... [IMG]http://*****************.com/smile/emthup.gif[/IMG] ps see my other post on my other 16v about rad fan issues
    10. Member 337GTiAndrew's Avatar
      Jun 22nd, 2005
      South Florida
      3,208
      a reliable car ie not VW
      01-26-2007 06:17 PM #9
      This looks hot!
      omg thats sweet
      Breast reduction surgery is like slapping god accross the face
    11. 01-26-2007 06:29 PM #10
      Quote, originally posted by plynch »
      A slow leak is not definitive, that could just mean you need a normal valve job. Before you buy new valves, clean one of the suspect valves, chuck it up into a drill press, mill or valve grinding machine (preferred) and check the runout on the valve then compare that to a valve that's known to be good.
    12. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      01-26-2007 06:53 PM #11
      yeah true i guess i could do that or lap them in with some clover compound and try again maybe? what is the best valve spring compressor? for head off the engine of course
      Modified by plynch at 8:16 PM 2-2-2007
    13. 01-26-2007 07:11 PM #12
      Lapping the valves can also serve as an effective diagnosic procedure. A couple turns with some fine lapping compound will leave a visible mark on the valve, inspecting those marks will tell you if the valve is making proper contact with the valve seat.
    14. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      trendy homeless camp, OR
      39,146
      german and british
      01-29-2007 04:22 PM #13
      ive seen them break at idle and sometimes you can get lucky then with engine speeds that low. otherwise i think its pretty much a garuntee that some will be bent...
    15. Member Big CADDY's Avatar
      Aug 28th, 2001
      Mt. Holly Springs, PA
      10,650
      01-29-2007 07:01 PM #14
      same thing happened to me and I was one of the lucky ones. The car runs like a raped ape.
      Just another reason to stay current with the belt. I didn't, but had it planned for the upcoming month.... go figure.
      Good luck
    16. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      01-30-2007 07:17 PM #15
      any valve spring compessors recommendations? mine is for aircooled and attaches to the outside springs clearly not going to work on the 16v
    17. 01-30-2007 08:16 PM #16
      Cheap way- 8" C-clamp and a socket with a hole cut into it so you can get the keepers out. Takes ages, but it costs maybe $20
    18. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      02-11-2007 10:01 PM #17
      these are the lifters at 137k miles they look worn to me....
    19. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      02-11-2007 10:01 PM #18
      Modified by plynch at 6:03 PM 2-11-2007
    20. Member Scuba2001's Avatar
      Jul 15th, 2002
      Greenville, SC
      11,269
      02-11-2007 10:10 PM #19
      Looks pretty worn to me. Hard miles.
      Scuba Steve
    21. Member 8716v's Avatar
      Sep 10th, 2006
      the jungle, FL
      488
      86.5 16v scirocco turbo
      02-11-2007 11:02 PM #20
      eastwood company the have them for 20 bucks and its the last one youll buy. the put a socket on the end and your in business. hope this helps.
    22. Member plynch's Avatar
      Aug 29th, 2006
      Buckhannon, WV
      2,611
      02-21-2007 09:44 PM #21
      got a website? not familiar with eastwood?
