Fourtitude.com - Any coil pack issues with 2.0T?
    Results 1 to 21 of 21
    1. 11-26-2006 03:27 PM #1
      So I pickup a 12,500km Audi A4 on Wednesday... Everything goes fine until on Saturday, the CEL goes on blinking, and my engine stutters and goes REALLY bad (no power, hesitating, etc.)
      The car will go in on Monday, but it seems to me like a problem very similar to the coil packs issues 2002-2004 1.8Ts had.
      Anybody experienced that? I hope it's not a sign of things to come.
    3. 11-26-2006 04:01 PM #2
      i did. col pack caught on fire. they made me pay for it cause i broke some clips trying to put the fire out. i was pumping gas in my car with the car off when this happened too
    4. 11-26-2006 04:44 PM #3
      Nurendra had a similar problem, num1 coil caugh fire
    5. 11-26-2006 04:47 PM #4
      Well no fire on my side, but that's scary
      Dec 3rd, 2000
      4,928
      2015 CC
      11-26-2006 04:52 PM #5
      are you trying to say if it catches fire i don't put it out cause i could break something doing so they can void the warrenty..
      some things service compartment say to get your money.. do you mind me asking how much it cost you.
      2015 VW CC Mods so far 19x9.5 35et 3mm spacers in rear square niche veronas 235 35 nitto tires.
    7. 11-28-2006 09:40 AM #6
      Turns out it was a failed coilpack, as I expected. Everything was fixed under warranty.
    8. 11-28-2006 12:42 PM #7
      Yes, my 06 GTI as well as my dad's 06 GTI both have had incidents of "coil pack failure." Never any fires involved though, damn. It happened when I started my car on Saturday and it shuddered with flashing cel, so I shut it off. Called NorthPenn VW Mazda and they told me to have it towed via VW roadside (free), then they gave my family a brand new passat rental (free), then they overnighted the coil pack and fixed my car (free). I'm never going anywhere else for VW issues. Thanks Northpenn.
      P.S. Not surprised coil packs are exploding that's VW for ya.
    9. Member
      Apr 17th, 2001
      NOVA
      508
      MKVI GLI; Routan
      11-28-2006 09:06 PM #8
      Recently I had it in the shop for a CEL that flashed under hard acceleration, then stayed solid. It also was obviously mis-firing etc while the light was flashing. They (Alexandria VW) replaced an injector coil on cylinder #2. They also found that cylinder #2 had excessive carbon build-up and they added cleaner to the top end, then changed the oil. All is well now and they did a fantastic job with my car. They also gave me a Passat to drive over the time it was in the shop. No more cold start issues either and she runs stronger than ever before.
      8,300 miles. GTI FSI 2.0
      Modified by Lief at 8:10 PM 11-28-2006
      Modified by Lief at 8:11 PM 11-28-2006
    10. 11-23-2007 03:32 PM #9
      Add my name to the list of coil pack "victims".
      2006 GTI w/30,400 miles.
      #1 cp replaced under warrantee this morning.
    11. 11-23-2007 08:01 PM #10
      Quote, originally posted by axthomson »
      How are they not in jail?
    12. Member OOOO-A3's Avatar
      Jul 20th, 2004
      KILG
      8,334
      2013 Volt; 1/35th of a Model ☰
      11-23-2007 10:03 PM #11
      Quote, originally posted by TRBO-GTI »
      Ahhhh, the opportunity to post this again..... http://oooo-a3.blogspot.com/2007/01/coil-failure.html
    13. 12-22-2007 02:09 PM #12
      I think I've got the same problem now.
    14. 03-17-2008 12:16 PM #13
      Thanks for the info. Cyl's 1, 2, & 3, so far. Burned out my #2 plug, Bill Brit in Fredericksburg said $140 to replace plugs - not under warranty. I said the bad pack caused the bad plugs, so they're covered.
      Long story short, they told me I was crazy. My attorney thinks otherwise. He say the laws are very specific; a warranty issue caused a chain reaction of failed parts and those parts are most certainly covered, regardless of "disposabilty" factor.
    15. Member trbowgn's Avatar
      Jan 9th, 2004
      Tosa
      1,028
      ALOT
      03-17-2008 12:35 PM #14
      My cylinder # 4 actually had the coil fail. I think it was more to do with the dealership cracking the casing of the coil pack than anything else when they replaced the camshaft. But I parked the car left it there for about an hour or so and came back out to a burning smell. When I opened the hood the wire harness was melted to the coilpack. Had to replace the coil pack and the entire harness.
    16. 03-17-2008 01:32 PM #15
      #3 CP failed on my A4 a few weeks ago. Dealer diagnosed, replaced, and had me on my way in a couple of hours.
    17. Former Advertiser
      May 17th, 2007
      Summit Point, WV
      9,888
      80,98,00,01,06,12,15
      03-17-2008 01:43 PM #16
      Failures are few and far between compared to the 1.8t but certainly still happen.
      I did more then I could count on 1.8ts working at the dealer and less then a handful on 2.0ts.
      Only failures we have had here on internal 2.0ts here have been related to water getting in and shorting at the plug. Dry them out and its fine.
      They are still going to happen though and I have seen fires so please be careful and if you start getting misfires check it out properly.
    18. 03-17-2008 02:12 PM #17
      I had coilpack 1 burn out at 10,000miles
    19. Member
      Sep 14th, 2002
      Hoboken, NJ
      891
      2008 VW R32 & 2010 Audi A3 Quattro
      04-17-2008 03:13 PM #18
      so have the redesigned the coilpacks? what are the permanent fixes on these coil pack issues? It seems like such a common issue since the late 90s as far as I can remember. My gf's car just had this issue and headed to the dealership for a fix. Do I need to request the dealer to change ALL of them or just the ones burnt out?
      thanks
    20. 04-17-2008 06:00 PM #19
      Quote, originally posted by ex2k »
      thanks
      dealers will only change the ones that are damaged, or causing a dtc/cel under warranty. They can change the currently operable at your request on your dime if you wish though.
    21. 04-17-2008 06:13 PM #20
      Quote, originally posted by D.Passat00 »
      That's not entirely true. On my '06 MkV GTI I was coming across the Tapanzee bridge w/ like 10k on the odometer and I was getting wicked misfires on cylinder #1, car buckin like crazy. Brought her in, they replaced the coil pack in #1. Left the dealer, about 2 miles out, bang misfire city again, this time on #4, they then replaced all my coils with the latest revision under warranty.
      Modified by BumbleBeeJBG at 2:34 PM 4-17-2008
    22. 04-17-2008 10:42 PM #21
      my advice? get a VAG-COM and spare coilpacks.
      http://forums.vwvortex.com/zerothread?id=3795419
