Fourtitude.com - jetta a2 swap
    Results 1 to 25 of 43
    Thread: jetta a2 swap
    1. 10-31-2006 10:43 AM #1
      ok i wanna know what the nost cost effective easiest to do swap in my jetta gl is
    3. Member ry_guy's Avatar
      Jun 4th, 2006
      FL :(
      3,148
      10-31-2006 10:44 AM #2
      LS1
    4. Banned eppy73's Avatar
      Nov 27th, 2004
      4,484
      10-31-2006 10:47 AM #3
      Modified by eppy73 at 7:48 AM 10-31-2006
    5. Member enriquejcu's Avatar
      Sep 16th, 2004
      Hitler's Asscrack, Ohio
      8,294
      turbo 5cyl AWD 6 speed
      10-31-2006 10:48 AM #4
      Aug 1st, 2002
      South Loop, Chicago
      9,061
      1991 LB6Z GTI Chicago River Flood Salvage Edition
      10-31-2006 10:48 AM #5
      If you're looking for simplicity and cost effectiveness, a swap probably isn't the best idea. Mine's pretty basic--I've got an 8v with a 2L ABA block and I love it. The Golf/Jetta II forum will probably tell you the only swap worth doing is a VR6. Unless you're a competent mechanic, you probably shouldn't attempt that, because even if a shop does the work, maintenance and repairs will eat you alive. Good luck.
    7. 10-31-2006 10:50 AM #6
      most cost effective and easiest swap is putting another 1.8 8v into it with lower km and better compression
      2016 Discount Brand S3
      1987 Peugeot PB-18 – Manual Power
      1986 Mid-Engine Supercar
      Aug 1st, 2002
      South Loop, Chicago
      9,061
      10-31-2006 10:54 AM #7
      Also keep in mind that if your car is stock, you'll really need to upgrade other components (suspension, brakes, etc.) which adds up considerably beyond the cost of the engine itself.
    9. 10-31-2006 11:02 AM #8
      A 200 shot of nitrous and a garage full of spare $100 8Vs is the best swap
    10. Member anarchyx34's Avatar
      Apr 27th, 2001
      Staten Island, NY
      5,647
      10-31-2006 11:04 AM #9
      If your're looking for simple and cost-effective, dont bother doing a swap in the first place. You've gotta pay to play.
      However I've heard that the 2.0 crossflow (aka 2.slow) motor is one of the easiest swaps. I just fail to see the point.
      Modified by anarchyx34 at 8:11 AM 10-31-2006
      '03 Jeep Grand Cherokee Limited V8
    11. Geriatric Member ATL_Av8r's Avatar
      Oct 17th, 2002
      Gapiana
      43,818
      10-31-2006 11:14 AM #10
      You didn't specify engine swap, so I'll say shifter knob [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      MemeGate 2012 - First Responder, post #2
      Buy my wife's old laptop!
    12. Member
      Aug 1st, 2002
      South Loop, Chicago
      9,061
      10-31-2006 11:17 AM #11
      Quote, originally posted by anarchyx34 »
      To be fair, I did notice a difference when I went from the 1.8 to the 2.0 in my '91 GTI, and my car puts down 108 whp with the most basic of performance mods.
    13. 10-31-2006 11:22 AM #12
      A friend of mine put the MKIII 2.0 ABA x-flow in his 91 Golf. He loves it and it was hard - but not impossible.
      The easiest is either another 8V or a 16v. With a VR swap - a BUNCH of stuff needs to be changed (subframe, wiring harness, etc...)
      You should check out the Jetta/Golf II forum for more info [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Banned
      May 24th, 2005
      3,366
      10-31-2006 11:26 AM #13
      Well for starters the 2.0 ABA is a helluva lot better than the 8v he currently has. It house stout internals and can take boost. It has ~118hp compared to the ~100hp of the 8v. It's not all that hard to swap and has more tuning options than the 8v.
      2L motor might be a pig in a the pig mk3's and mk4's, but in a light mk2 they're pretty respectable
    15. 10-31-2006 11:48 AM #14
      VR6 swap on your car would be dead simple. Plug and play wiring, drill a half doz holes and swap a few parts. It could probably be done for around $2k.
    16. Banned
      May 24th, 2005
      3,366
      10-31-2006 11:50 AM #15
      Quote, originally posted by CannuckCorradoVR6T »
      Ummm....I would doubt it. $2k for that kind of swap? I would hope he's done other mods before that happens
    17. Member bhtooefr's Avatar
      Dec 22nd, 2005
      Newark, OH
      17,339
      16 Prius, 00 Miata, 11 TerraTrike Path 8
      10-31-2006 12:02 PM #16
      The Northstar is hardly cost effective.
      For a little over $1,000, not counting labor, you could get a wrecked Mk3 TDI, and do a 1.9TDI swap.
      Almost VR6 torque (and it hits at low RPMs, too), and slightly less horsepower than you have now. And THAT is easily remedied (and then some) with a chip and injectors, for under $600.
      Oh, and reesie, I thought everyone in there was all going to 16v turbo setups now.
      Modified by bhtooefr at 12:07 PM 10-31-2006
    18. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      32,254
      '66 Beetle (X2) '08 Fit
      10-31-2006 12:19 PM #17
      Unless you're really attached to the car, it's most likelly cheaper to sell yours and buy either a 16V or whatever it is that you want. If you wish to buy a car that already has a swap, make damn sure that it was done well. If it wasn't, you're out alot of money. Alot. Whole bunches.
      My car is factory (though very worn) and is a blast to drive. If you can find a 16V for a decent price, you get great seats (Recaros in mine) and pretty good brakes/suspension. I'm considering a swap in the future, but my swap would be putting my engine, suspension and brakes into a better condition Golf/GTi. (mines bent a little and has a leaky windshield.) If I go that route, I'll have to find out the difficulty of changing over my multifunction dislplay, as I rather like it.
    19. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      32,254
      10-31-2006 12:20 PM #18
      Quote, originally posted by bhtooefr »
      I think that was a joke.
    20. 10-31-2006 12:20 PM #19
      Quote, originally posted by RedIrishman »
      ya, that wouldnt include brakes or suspension. But, the easiest, fastest, most cost effective way to do this swap is to buy a whole donor car. Then the suspension, brakes, wiring and associated plumbing is all there. VR6 conversions are totally worthwhile, bone stock MK2 vr's can run mid to low 14's!
    21. Member
      Aug 1st, 2002
      South Loop, Chicago
      9,061
      10-31-2006 12:24 PM #20
      I've never seen a TDI donor in the $1k range, and I've been looking for a couple of years.
      The point is, they're gluttons for punishment.
    22. Member bhtooefr's Avatar
      Dec 22nd, 2005
      Newark, OH
      17,339
      10-31-2006 12:29 PM #21
      See, what you do is, you look around on TDIClub, and when someone posts "I rolled my Jetta" or something like that, you PM them, and offer them $1000.
      I really need to find one myself, but I have a friend with a 16v GTI that wants to be back in a diesel MUCH more than I want a TDI.
    23. 10-31-2006 12:30 PM #22
      I saw a well totalled mk3 tdi sell for at least 1500.
      I guess if it is possible on the tdiclub.com, I'm just quite skeptical of it.
    24. 10-31-2006 12:37 PM #23
      dont even start on that. My neighbour rolled his 99 TDI and could have bought it back for $800.....but he didnt. I would have loved to do the TDI swap, the car it would have gone into was diesel originally! Damn.
    25. 10-31-2006 01:40 PM #24
      1.8 16v, 2.0 16v, 1.8T, VR6
    26. 11-01-2006 12:27 PM #25
      so the aba 2.0 is what the 2.0 8v cuz i hear there pretty good when turbo'd what would i need to do that swap ?
