Fourtitude.com - DIY Oil Pan on 2.0L MKIV, done correctly finally!
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 61
    1. 07-07-2006 02:09 PM #1
      DIY on the oil pan for the 2.0L MKIV even though it's essentially the same thing as bhb399mm's DIY for the VR6.
      So bam like in the other DIY by bhb399mm, you'll need:
      -16mm and 19mm sockets
      -Socket extention bar
      -A ball headed 5mm allen bit or key NOTE: Recommended: 10mm flex or swivel socket
      -Bit/Socket driver
      -Rubber mallet or hammer + hockey puck
      -New oil pan and sealant
      Optional: New oil, filter, hacksaw.
      I bought the oil pan and sealant from ECS for $117 shipped.
      Well of course, you must start with this, put on some tunes!
      So of course make sure the car is secure where it is chocks the rears and all that good stuff. If you couldn't find a ball headed allen bit like me, you can improvise.
      HOWEVER. Upon replacement of the infamous two bolts near the tranny, the use of the allen key method may end up stripping the bolt heads. For this reason, I suggest using the following combination:
      The 10mm flex head is available at Sears and is completely worth it.
      Make sure you drain your oil too!
      There is a pan cover with a bolt on the front side and two push in fasteners on the back. Remove this.
      Remove the 5mm hex bolts around the pan, there are two that are hidden next to the transmission, use your improvised or nicely bought tool.
      There are three 16mm transgina bolts you need to remove.
      A rubber mallet was no where to be found, so again improvisation is the name of the game. I used a NHL practice hockey puck that hit me in the head a few years ago at a game and a hammer to break the pan loose.
      Cleaning up of the old sealant was accomplished with help of Denatured Alcohol. Make sure all of the old sealant is removed.
      Get the pretty new pan, dress it up with a 2 - 3mm bead of new sealant, do the same on the block, running it on the inside of the bolt holes. Make sure the surface on the block is clean!
      Do the pan up with the 5mm's using either the ball head or regular, then do the 3 tranny bolts. Torque them to spec if you're into that sort of thing (I am after stripping the drain plug).
      11 ft lbs on the pan to block bolts
      33 ft lbs on the pan to tranny
      22 ft lbs on the plug.
      I believe you can refill the engine after 30minutes but DO NOT run it for at least 12 hours to allow the sealant to properly cure.
      Modified by caliginousface at 6:53 PM 7-11-2006
      Modified by caliginousface at 9:47 PM 7-11-2006
    3. Member J.Owen's Avatar
      May 31st, 2001
      'Murica
      7,496
      '16 Jetta,'13 Pathfinder, '98 323is
      07-07-2006 02:37 PM #2
      hmmm, i want an oil pan shield. mine just hangs out there to dry.
      BlownEuros.com
      Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    4. 08-24-2006 01:44 AM #3
      after 2 pans i went with the steel reinforced one, for $10 cheaper
      http://www.germanautoparts.com
    5. 08-24-2006 02:47 AM #4
      awesome write up....
    6. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      8,306
      2008 BMW 335i, 2010 Rav4 V6 Ltd.
      08-24-2006 08:46 AM #5
      Good stuff! This will be usefull for anyone doing a turbo setup and tapping the oil lines to the pan. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      P.S..
      let me see if I can get it to stick.
      Modified by vasillalov at 8:47 AM 8-24-2006
      Quote Originally Posted by MAG58 View Post
      Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
      A turbocharger is a device in where exhaust gases go in, witchcraft happens, and then you go faster.
    7. Member chrissor's Avatar
      May 5th, 2004
      canada
      1,885
      08-24-2006 11:05 AM #6
      gloves are for sissy's just kidding, good diy [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      .:R
    8. Member Fire32NJetta's Avatar
      Feb 17th, 2004
      1,125
      2003 Jetta TDI
      08-24-2006 12:38 PM #7
      well i have a pan gasket for my mk3 is sealant still reccommended or is it an alternative to useing a gasket
    9. Member 16vsilverstreak's Avatar
      Dec 5th, 2001
      Bristol, TN
      408
      '82 2.0 16v Rabbit truck, 1983 Porsche 928S, 2009 2.0t 4motion Tiguan
      10-04-2006 11:38 PM #8
      MKIII use gasket IVs use sealant.
    10. 11-16-2006 02:18 AM #9
      ol thread with helpful information..... bump it up....
    11. 11-22-2006 01:11 PM #10
      Straight to my watched topics [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. 11-22-2006 03:11 PM #11
      You should circle around each hole with sealer. Don't just run it along the inside.
    13. 11-22-2006 08:22 PM #12
      I just used this DIY but just out of curiosity- What happens (or could happen) if you don't wait 12hours for the sealant to set????
    14. Member ENRGZR's Avatar
      Oct 11th, 2006
      Lacey, Wa
      2,595
      91 Golf, 99.5 Jetta, 07 Rabbit, 13 Focus ST
      11-30-2006 12:55 PM #13
      I can picture liquid pushing out where the sealant hasn't set.
      XBL/PS3: ENRGZR
      AKeuro / CCA Motorsport / Air by Santi / Fifteen52 / C2 / Trac Wrap
      Quote Originally Posted by 5P4RK4 View Post
      A dozen 1000 miles is 120,000 not 12000, thats 1.2 1000 miles.
      edit. wow I fail. Im going to leave that there to remind myself not to do math.
    15. 12-09-2006 05:43 PM #14
      what tool do you need to remove this bolt? 10mm allen?
      i found out that jiffy lube stripped my pan, so i'm doing this myself, and really overdue for an oil change
    16. Member snwsurfer's Avatar
      May 7th, 2002
      Lombard, IL
      165
      12-09-2006 06:25 PM #15
      Just used this today in the school parking lot... gotta love flying ice chunks on the freeway.
      I'm not sure what size that is.. my car never came with that steel pan... I think it's time for a dieselgeek skidplate
    17. 12-11-2006 03:23 AM #16
      Quote, originally posted by klee »
      no one?
    18. 12-29-2006 03:21 PM #17
      I ended up using an allen key I believe. Not sure on the size though. The new pan wouldn't accomodate the pan cover though.
    19. 01-16-2007 01:37 PM #18
      Word to the wise, when you buy the flex 10mm socket, MAKE SURE you buy the 1/4 drive version, not the 3/8's like I did
      The 3/8's drive one won't even fit up one of the tranny/pan holes
      I like to ride my bicycle....
      99.5 2.0 GTI - I hate it, but its paid off and has heated seats.
    20. 02-24-2007 12:04 PM #19
      What did you use on the hidden bolt closer to the front of the car cuz i cant get that one off someone help me out
    21. Member beatman's Avatar
      Oct 31st, 2004
      102
      99.5 jetta - 2.0
      04-23-2007 01:21 PM #20
      thanks for the write up...i replaced my oilpan last week....used a hybrid pan from ECS...
      thanks again!
    22. Member SLVR SLUG's Avatar
      Dec 9th, 2006
      2,317
      2004 Golf 2.0T 1989 Chevy S10 Blazer 4x4
      11-18-2007 12:14 PM #21
      * book mark* im def keepin this around for when i switch my pan over to a pre tapped one for my turbo setup. thats right i said it. pre tapped. compliments of black forest industries. http://store.blackforestindust....html
      the new vortex sucks!
      R.I.P. #2688... you will be missed.
    23. 11-18-2007 03:11 PM #22
      Your welcome for the unarchive .
    24. Member SLVR SLUG's Avatar
      Dec 9th, 2006
      2,317
      11-18-2007 11:34 PM #23
    25. 05-16-2008 11:29 PM #24
      Hello, what type of sealant should I be looking for in the store?
    26. 05-25-2008 01:20 AM #25
      hey, i am in the middle of this DIY and im stuck trying to get the old oil pan off the car. I have removed all screws connecting the two but it just wont budge. I have tried a hammer to wood, a mini sledge hammer to wood., and direct blows. It just wont come off. Any ideas how I get it off?
