Fourtitude.com - MacMini carputer concept even more compelling now
    Results 1 to 18 of 18
    1. Member OOOO-A3's Avatar
      Jul 19th, 2004
      KILG
      8,437
      2013 Volt; 1/35th of a Model 3
      04-05-2006 09:49 AM #1
      Now you can install a Mac Mini (intel processor) in the perfectly-sized glovebox CD changer cubby, use it for in-car media with the included FrontRow,
      aaannnnnndddd......
      With Boot Camp or Parallels virtualisation you can have all the VAG-COM integration you want by dual-booting into Windows or running Windows in a VM (non-emulated) environment.
      Still need a good touchscreen mounting solution.
      Still need a job so I can afford to do this... anyone hiring an IT Director/CIO/CTO in the Delaware/Philadelphia area?
      Modified by OOOO-A3 at 9:37 PM 12-3-2006
    3. 04-05-2006 01:06 PM #2
      Just heard about Boot Camp, shweet. Call of Duty in the A3...hells yes.
      Seriously, I totally want to add a mac mini one day. Are there any good recources for doing this to an A3 yet?
      There is tons of info out there for adding a mini to a Prius.for example. Or head over to PriusChat
      Modified by garlinghouse at 1:09 PM 4/5/2006
    4. Member A4MouseJunior's Avatar
      Mar 9th, 2003
      T.O
      498
      2008 Audi TT 3.2, 2006 Audi A3 2.0T, 1998 Audi A4 1.8T
      04-05-2006 02:01 PM #3
      http://www.mp3car.com
      I am actually in the process of doing a mini pc install. I got all the hardware install already and is up running, just need to work on how to place the monitor on the centre console.... take's a lot of time. I will post some pics later.
    5. 04-05-2006 02:28 PM #4
      Quote, originally posted by A4MouseJunior »
      Do us up a fourtitude DIY while you are at it. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. Member A4MouseJunior's Avatar
      Mar 9th, 2003
      T.O
      498
      04-06-2006 12:55 AM #5
      Another write up?? I think about it.. depends on how many ppl are interested.
      For now, here's are the pics:
      I still have to put the monitor up to the console, the double din wont fit my Xenarc 7" tounchscreen. My option is to have the radio put inside the glovebox, move down the climate control and then I will have the space to put it there.
      More pics / post to come as I have more progress on this.
    7. 04-06-2006 05:31 PM #6
      how do you plan on moving the climate control down? I was looking into this when I had the dash apart installing my dension icelink. I just couldnt find a way to move the control down without purchasing the the climate control designed for the nav equipped cars
    8. 04-08-2006 11:15 AM #7
      This is awesome. I'm a computer engineer type, and i'm definitely going to try this out. My A3 is on order, won't get here till June/July, so I have some questions. Especially about the A3 interior, since I only saw one once on my test drive, and it didn't have the nav+ in it. Where would you mount the pc/mac? Under a seat, in the boot, up front?
      Here are the main issues that come to mind:
      1. Power - I'm guessing it you need to wire it to the car battery, if not how are you handling this?
      2. Display - I saw you have a touch screen, which is cool. Is there room for it via the nav+ up front? Anyway to hook into the nav+ display?
      3. Input Devices - Same thing, as display. Touch screen or nav+, or even something else? Wireless keyboad w/touchpad build in would work too.
      4. Audio - Wiring it into the bose shouldn't be THAT difficult, but this is my first VAG car, so I have no idea what I'm up against.
      5. Internet Access - I'm thinking there's got to be a way with a cell phone to do this. I have a blackberry, and i know there's ways to connect laptops to it for broadband access via bluetooth.
      Modified by kyeo138 at 1:20 PM 4-8-2006
    9. Member OOOO-A3's Avatar
      Jul 19th, 2004
      KILG
      8,437
      04-08-2006 11:56 AM #8
      Quote, originally posted by kyeo138 »
      If you don't have the glovebox CD changer, then a Mac Mini will fit where it would go in the glovebox. If you do have the glovebox changer, think how much better a Mini full of iTunes would be than 6 CDs, then pull it out.
      Here's the power supply/power button solution:
      http://www.carnetix.com/forum/viewforum.php?f=6
      See navplus.us for how to hook into the nav display. If you don't have nav, then positioning a display is the real issue. A guy in (Portugal?) did a nice install in the space below the climate control, but I don't have the link to the photos handy.
      Touchscreen, of course. Bluetooth keyboard, or a FrogPad. Edit: Definitely a Griffin PowerMate as well.
      Assuming you'd bag the 6-disc changer.... get the interface that plugs into the changer connection and gives you standard L&R RCA inputs. Go from the audio out of the Mini to those inputs, and your 'changer' input is now whatever is piped out of the Mini. EDIT: The DICE iPod interface has Aux In as well, so it would be a perfect audio solution.
      5. Internet Access - I'm thinking there's got to be a way with a cell phone to do this. I have a blackberry, and i now there's ways to connect laptops to it for broadband access via bluetooth.
      Bluetooth phone from Cingular with Cingular EDGE data (like a Motorola V551 or V557, the RAZR doesn't have EDGE data, only GPRS, which is slower), and WiFi when you're parked near a hotspot (the Mini has both bluetooth and WiFI built in.) I use my V551 with my PowerBook frequently.
      Modified by OOOO-A3 at 9:35 PM 12-3-2006
    10. Member threethirteen's Avatar
      Mar 11th, 2004
      Silverthorne, CO
      4,528
      2002 A4 1.8T Quattro
      04-08-2006 05:37 PM #9
      find out what it would take to swap your climate controls for the controls out of the B5.5 A4 and then you should be able to fit your screen in there...or get rid of your radio and run all of your music from the computer. you can get a radio tuner for the computer so you will still get radio, i don't know how sirrius would work...but sirrius sucks...
      or what about the A3 with navigation? what would it take to fit the center console in there? doesnt that have a 7" screen?
      .:EDIT:.
      also, i would look into the addition of VAG-COM if you were to do a mac mini...does the software come in mac platform? cos it's a definate plus to have it there hardwired whenever you want it.
      Modified by threethirteen at 5:39 PM 4/8/2006
    11. Member Smartass's Avatar
      Aug 8th, 2000
      Calgary, AB
      706
      2000 VW Jetta 1.8T, 2003 BMW 325i, 2010 Mazda5 GT, 2006 Audi A4 2.0T Quattro Avant, 2012 VW GTI
      04-08-2006 10:40 PM #10
      You mean the B6?
      There was never a B5.5 A4, just a B5.5 passat.
      Either way I really doubt it would wire right up and work, probably a completely different setup.
    12. Member threethirteen's Avatar
      Mar 11th, 2004
      Silverthorne, CO
      4,528
      04-08-2006 11:23 PM #11
      Quote, originally posted by Smartass »
      You mean the B6?
      thats an interesting thought.... in 99.5 they gave the A4 a little updo. new center instrument panel, one-piece headlights, new sidemarkers, fog lights, larger passenger mirror, additional option of HID. then in 2001.5 they added the K03 sport and i believe DBW...commonly known as the B5.5
      and in the +99.5 they changed around the climate control module so the could fit in an optional navigation. i have seen it before where peopl made a fiberglas instrument panel for a xenarc 7" touch screen...but in most instances they had to use the later model climate controls.
      Modified by threethirteen at 11:31 PM 4/8/2006
    13. Member OOOO-A3's Avatar
      Jul 19th, 2004
      KILG
      8,437
      04-09-2006 12:22 AM #12
      Quote, originally posted by threethirteen »
      /QUOTE]
      Swapping the controls for the double-din A3 version has been discussed to death on here. Try searching.
      [QUOTE=threethirteen]also, i would look into the addition of VAG-COM if you were to do a mac mini...does the software come in mac platform? cos it's a definate plus to have it there hardwired whenever you want it.
      <sigh> does nobody read the thread before posting? As I said in the initial post:
      Quote, originally posted by OOOO-A3 &raquo;
      Modified by OOOO-A3 at 9:39 PM 12-3-2006
    14. Member threethirteen's Avatar
      Mar 11th, 2004
      Silverthorne, CO
      4,528
      04-09-2006 09:59 AM #13
      i guess in my experiences with it, most mac to windows software runs really really slow...but then i guess i wasnt running a G4/5
    15. 04-09-2006 10:56 AM #14
      Quote, originally posted by threethirteen &raquo;
      No the new Mac's have the intel Duo, (not powerPC) and will be competely windows compatable. It not like running vitual PC, you will be able to run windows directly.
      Modified by judgegavel at 10:58 AM 4/9/2006
    16. Member OOOO-A3's Avatar
      Jul 19th, 2004
      KILG
      8,437
      04-09-2006 11:37 AM #15
      Quote, originally posted by judgegavel &raquo;
      Modified by OOOO-A3 at 9:38 PM 12-3-2006
    17. Member a3lad's Avatar
      Aug 6th, 2005
      DC
      2,236
      04-09-2006 01:05 PM #16
    18. Member threethirteen's Avatar
      Mar 11th, 2004
      Silverthorne, CO
      4,528
      04-09-2006 10:13 PM #17
      no, we just read the title then start ranting...
    19. 12-03-2006 09:03 PM #18
      Interesting idea for mounting a video monitor in an A3 with concert II.
      http://www.solocarputer.com/ph...art=0
