I still have to buy my belt.I am actually looking for a belt that is longer than the original VWMS 64"
The pulleys I boughtI have not decided yet which path I am going to take.Either the original or the Red Path.Does gates have belts in all sizes?
#141
thank you for the prompt post,i'm just curious.... what belt are you running, any part#'s .... mine is alot longer... and it is a gates t098.... nothing else matches this....
how many belts did he include with the cogs..... or did he tell you where you could get shorter belts... etc...
this is a pretty unique setup.... looks like just you and I are the only ones running this setup![]()
david
#142
#143
that toothed belt in your setup doesn't look bad.... but there are only maybe 4-5 teeth grabbing the waterpump cog...mine is alot longer..... i've spent a good month trying to source belts that were in the same specs as the gates t098 belt.... nothing comes close.....
i must have gone through several hundred belts at napa, acme, etc...so I had to come up with various pullies to make the belt fit properly... but it still didn't work out quite good
take a look at the gates website http://www.gates.com and look at the t098 timing belt... that will give you the specs on my belt.... i'm sure we have the same cogs.....
p/s if you gave me a number on your belt, we could do some further digging
david
#144
yes but my setup is going on an 8V not a 16V
take a picture of your engine and maybe we can work out something.....would be nice to see the path you want to take.
#145
i'll take some pics soon....but who's 16v-g60 with the cogged setup does that belong to?
any more pics of that?
so no part #'s on your belt? contitech or gates???
david
#146
Quote, originally posted by N_TENSETUNING »
Some guy in Toronto,Jerome would have more knowledge of it than me.I just came across those pictures and I posted what I had
Have not purchased the belt as yet.The VWMS gears have the same tooth pitch as the 16V/20V belts which are the same as the Honda Belts/many other Japanese brands.Take a piece of string and wrap it around your cogs and go into Pepboys/Napa and start searching.
Please post pictures of your gear setup asap
Kinda excited...![]()
#147
okay ... then we have a totally different pitch in coggs.... because i checked every single timing belt that vw and audi use.... nothing comes close....i'll I.M you
david
#148
Quote, originally posted by Wizard-of-OD » I really like that setup, except for the amount of wrap (or lack there-of) on the waterpump. Definitely more likely to shear teeth of the belt at high rpm then with more wrap on the pulley. An idler would help out.
Where can the cogged pullies be sourced from?
I'm not so sure about the owner being from Toronto though, the pics are definitely look to be from europe, although the pics are hosted at VWoT..? Only 16vG60's in the GTA that I know of are mine and Marek's (not sure if he still has his).
Edit: Just looked at some more of the engine pics, looks like the car the engine has the MC mounted on the right side, so right hand drive. Definitely not a Toronto car.
Modified by Kaddy at 10:50 PM 3-11-2005
#150
i'm not sure that the trouble of a cogged belt set-up is worth all the effort...if you have the serpentine belt routed properly there shouldn't be any problem with slippage.of course...if it's being done simply because it's BLING NASTY then alright
#151
i told ya (wizard of OD),there is no way you will find anything vw or audi that will fit those belts.... the pitch is way off...
believe me ... i spent a good month looking into all of this.
the only way you are going to get the proper belts is to have (sciroccoR) read you off the part#'s off his old belts.
or use the one i'm using... gates t098
i did find industrial belts the proper sizing, but the teeth were not deep enough.... it would shread in a matter of secs.....
d
#152
or use the one i'm using... gates t098Does this belt come in 64" long?
My apologies before.I was going by what I was told until we actually carried out a practical.This is all Peter had to say:
Quote, originally posted by SciroccoR »
The belt length is about 64”. The number on the belt is 58174X25mm. It is a gates belt Power grip HTD and was made in germany.
#153
i believe the gates t098 is much longer than that.... i have the specs at home... you can also find the full specs on it at http://www.gates.comit's a pity that peter didn't have any actual part#'s though....
hey wizard of od.... maybe we should keep our stuff off this thread as it isn't relevant to any of the others.
Feel free to I.M. me
look forward to getting the belts thing squared away
david
#154
Do you happen to have some info on this intake? It's obvious is a custom intake but it looks pretty clean, like it came from factory.
Check out some of my vortex feedback: http://forums.vwvortex.com/showthread.php?952415
#155
Same intake I have.
Audi S2 or RS2, cut to fit
#156
that is a factory audi 5cyl 20v manifold (came on audi 100's turbo)they cut the 5th runner off and tigged a new flange on the end to accept that g60 tb
definately custom.... and nicely smoothed
oh... that fuel rail looks like a 1.8t one, with longer ends
david
#157
Quote, originally posted by N_TENSETUNING » that is a factory audi 5cyl 20v manifold (came on audi 100's turbo) they cut the 5th runner off and tigged a new flange on the end to accept that g60 tb
davidAlmost right Dave
Audi 200's what kinda of audi parts guy are you?
200's were turbo's 100's were not.
#158
Quote, originally posted by Volk14 » like it came from factory. It did
Audi Inline 5 20V Turbo Intake Manifold that has been chopped.
Audi 200T - 3B
Audi S2 - ABY
Audi RS2 - ADU
Choose your engine code and go hunting![]()
#159
another way to do the cog belt set-up is to use timing gears from a TDi or something. the only problem with that is you're extremely limited as to the size of the supercharger pulley...momentum tuning solved this problem by running two G-laders to effectively double the boost...mated to an ABA block and head; this engine is a killer. walks all over M5's from 60-100mph.check it http://momentumtuning.com/site...ject2/
#160
oops.... typo..... i mean audi 200's turbothanks chiarappi/mk2 charged
p/s i'm now a parts guys that doesn't do audi ....to answer your question...
give me a call at home and i'll fill you in
david
#161
It seems like some low end torque (off boost) would be lost with those short intake manifolds. Has anyone actually been able to compare? I like how the short ones look and that they're not over the hot valve cover but wouldn't want it to decrease performance at all.
#162
Quote, originally posted by LooseNut » It seems like some low end torque (off boost) would be lost with those short intake manifolds. Has anyone actually been able to compare? I like how the short ones look and that they're not over the hot valve cover but wouldn't want it to decrease performance at all. That is the theory, but with a supercharger, as soon as you lay into the throttle, you're in boost, so I would assume that you could compensate with just adding a little more throttle, if there is a noticeable loss at all.
#163
In my case, I did a short runner and AT cams at the same time. The midrange torque wasn't affected compared to the factory intake with stock cams (220-230ft-lbs ~4500 rpm for both). The new combo pulls much harder for another 1000 rpm, at least on the top end, though.
#164
Has anyone had problems of higher runing oil pressures on the 16v and causing damaged oil seals on the charger? Do 16v usually run higher pressures than the g60?
#165
Quote, originally posted by jwatts » In my case, I did a short runner and AT cams at the same time. The midrange torque wasn't affected compared to the factory intake with stock cams (220-230ft-lbs ~4500 rpm for both). The new combo pulls much harder for another 1000 rpm, at least on the top end, though. yeah, but you guys are talking about on boost. I really hate the sluggishness of a low compression/displacement motor while off boost in stop and go traffic.
#166
Quote, originally posted by BlownGTT » Has anyone had problems of higher runing oil pressures on the 16v and causing damaged oil seals on the charger? Do 16v usually run higher pressures than the g60?
If you get the feed from the back of the head, it's ok, I tried it from the front oil flange, popped a seal.
#167
Quote, originally posted by OttawaG60 » If you get the feed from the back of the head, it's ok, I tried it from the front oil flange, popped a seal.
thats when using the 16v block and not the g60 block?
#168
Quote, originally posted by CORRADOFREEK » thats when using the 16v block and not the g60 block? Same difference.The Oil pressure @ the head whether 16V or 8V is going to be lower than that @ the oil filter flange.
#169
Yes, I am using the 9A long block.
#170
so you actually drill the block? WHere abouts is this? is regarding a 9a block![]()
#171
there is a hole for it right where the one is for the g60 block , you just need to drill it all the way . ( it is right near the oil filter , tothe left of it )
i have a 9a and need to drill mine also . i chose to not drill the pan .
sorry , thought you where talkign about the oil return line .![]()
i was just gonna get my oil from the side f the head , but if this is the case , where do i get hte feed line from on the back of the head ?
Modified by herby53-akaherby53 at 1:33 PM 4-19-2005
Modified by herby53-akaherby53 at 1:34 PM 4-19-2005
Up and Live >>> www.Herbys53.com <<< sick of the BS , check it out :thumb:
860-798-5227 TEXT anytime
Herbys53 VW/Audi Corral May 29th Lime Rock Park Ct.
53Motorsports-Koni/APR/TT/Bilsteins/Oem+/Service:clap:
#172
Quote, originally posted by herby53-akaherby53 » where do i get hte feed line from on the back of the head ? Where the stock Oil pressure switch is?
#173
forgot to ask, using the pg block, can i use the 16v trans? for some reason my mind is saying no due to the clutch flywheel setups
#174
Quote, originally posted by CORRADOFREEK » forgot to ask, using the pg block, can i use the 16v trans? for some reason my mind is saying no due to the clutch flywheel setups Clutch disc is all the you need to change, output shaft is different between the 2 trans.
#175
disregard the statment made earlier, it was late, and i was looking at a vr6 flywheel instead of the g60 flywheel
Modified by CORRADOFREEK at 5:20 PM 4-29-2005
