+ Reply to Thread
Results 1 to 4 of 4
Thread: dtc cylinder 1 misfire...2001 jetta vr6...spark plugs?
  1. 04-19-2004 11:23 PM #1
    hey guys...
    i feel like i lost power..im chipped....but dont feel it anymore...got dtc that says cylinder 1 mis fire....i always use super mobil gas...so i know its not bad fuel that caused it....maybe spark plugs? might have to change them? im around 30,000....any ideas?
    changed o2 sensor today...maf is only 3 weeks old.
    thanks
  2. Member f1forkvr6's Avatar
    Jun 10th, 2002
    NH
    8,131
    2007 BMW E86 (z4 Coupe ... no, the top doesn't go down) , 2001 SAAB 95
    04-19-2004 11:35 PM #2
    Pull 'em and look.
    Also, check for bad wires & a cracked coilpack.
    Confused? Search for "coilpack" and bad wires.
    No more VW
    ~later~
  3. 04-20-2004 05:35 PM #3
    Quote, originally posted by f1forkvr6 »
    Pull 'em and look.
    agreed....
  4. 04-26-2004 12:23 AM #4
    I've been having a misfire issue as well. My VR6 is stock. Had a bad coil pack replaced about 2k miles ago and just replaced a faulty ground wire. But I'm still having misfire / loss of power below 3k rpm.
    My pal thinks I should get the O2 sensor replaced (58,000 right now). I even tried a couple doses of fuel injector cleaner for a cheap fix, but no good.
    Anyone think I still have wiring problems?
+ Reply to Thread
